Old 05-31-2014, 11:41 AM   #1
10Tim
Here for the fun
10Tim's Avatar
Drives: 10 Series FR-S #2478
Mixing Oil Brands?
I have four quarts of Penzoil Platinum 0w-20, and two quarts of Royal Purple 0w-20.
Both synthetic oils meet or exceed API-SN and ILSAC-GF-5.
I don't see any reason why I couldn't use the two brands together for my next oil change, but I'm just wondering if there is some reason I shouldn't that I'm not aware of.
Yes or no?
P.S. Save the "you'll blow up the world" comments for another time.
There's just Not Enough Hours in The Day
On Flickr http://www.flickr.com/photos/24663968@N00/
On Instagram XLTimbo
10Tim is offline   Reply With Quote
Old 05-31-2014, 11:50 AM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
unless it says not compatible with other oils on the bottle you're fine. Its the same as changing the oil on a car with a remote oil cooler and using a different brand. Maybe not 2 quarts worth, but you get the idea.
The Following User Says Thank You to Reaper For This Useful Post:
10Tim (05-31-2014)
Old 06-01-2014, 03:10 AM   #3
humfrz
I reckon it would be OK.
humfrz
10Tim (06-01-2014)
Old 06-01-2014, 08:34 AM   #4
JFox
Drives: 2014 Scion FR-S
Okay I'll throw in my 2 cents here. Simply speculating, after an oil change, the "extra stuff" in the oil is usually used up. When it's new you're mixing fresh chemical additives.
That being said I seriously doubt anything bad will happen. How many people have had to add oil to their car in an "emergency situation" and didn't have the same kind of oil laying around? More so think how many people get their oil changed at a shop then just add whatever later.
JFox is offline   Reply With Quote
The Following User Says Thank You to JFox For This Useful Post:
10Tim (06-01-2014)
Old 06-02-2014, 10:15 AM   #5
bluesubie
Yes or no?
oH NoES! dON't put PUrpLE fOO-fOO kiDDiE jooS in yR caR! You'll blow up the world!
ASTM D6922 covers you.
It is important that engine oils from different manufacturers be homogeneous and miscible with each other, because operators of automotive engines often do not have prior knowledge of the manufacturer of the oil that is currently used in their application, and engine failure can occur if oils are combined that do not stay homogeneous and function properly.
http://www.astm.org/Standards/D6922.htm
-Dennis
bluesubie is offline   Reply With Quote
The Following User Says Thank You to bluesubie For This Useful Post:
Sportsguy83 (06-02-2014)
Old 06-02-2014, 11:36 AM   #6
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Foaming risks, aside from that it's all good
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
What are some good brands/rims KamakazeProject Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 12-14-2013 03:32 AM
Mixing Transmission Fluids? l0aded Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 06-27-2013 01:45 PM
Concave Face : Best Brands? ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 03-01-2013 01:28 AM
windshield wiper brands? 7thgear CANADA 10 01-22-2013 10:23 PM
What is it that makes people mixing up the GT86 with a Supra Killerbee Scion FR-S / Toyota 86 GT86 General Forum 31 12-20-2012 02:24 PM
