Old 09-30-2014, 03:09 PM   #1
brzjun
tire fitment question
I got 18x9.5+40 Te37 square setup. Wondering if Hankook Evo 255/40/18 will clear? Thanks
brzjun is offline   Reply With Quote
Old 10-02-2014, 07:01 PM   #2
PERRIN_Chris
Drives: 2014 Subaru BRZ
Send a message via AIM to PERRIN_Chris
What suspension are you running? If you're running springs, it probably won't clear in the front, but it should be fine in the rear. I'd run 35 series to make the tire size closer to stock.
PERRIN_Chris is offline   Reply With Quote
Old 10-02-2014, 07:35 PM   #3
BRZZZZZZZZZZ
Car Nut
BRZZZZZZZZZZ's Avatar
Drives: BMW 335d, Toyota Echo RS, FRS
Depending on suspension, but I say unlikely to fit. I run 255/40/17s on 17x9 +35s like many others on here and I need -3 degrees of camber to clear my fenders with a modest 20mm drop.
BRZZZZZZZZZZ is offline   Reply With Quote
Enkei T6S wheel and tire fitment question chenshuo Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 03-30-2014 09:25 PM
Tire fitment help!!!! PHOTOS! FRSEVO Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 10-04-2013 07:48 PM
Tire fitment question??? Dan@AWD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-31-2013 10:53 AM
need help with wheel/tire fitment bjun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 07-04-2013 10:34 PM
Tire/Wheel fitment tool bakilman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-02-2012 06:19 PM
