Old 09-30-2014, 12:47 PM   #1
Composite
Drives: 2013 Subaru BRZ
Need Major Advise 18x8.5 + 40 offset
I am looking into purchasing some wheels, I already tried the fitment calculator but I had no success trying to find the fitment I am posting about. The rims are 18x8.5 with a + 40 offset . Lug Pattern is 5x114 and the tires would be 225/40/18 . Does anyone know if this will fit correctly? Also I plan on getting a Sportline 1.4" drop in the future with these rims.
Thank you in advance.
Composite is offline   Reply With Quote
Old 09-30-2014, 12:53 PM   #2
gramicci101
Off Topic
To fit 5x114 you'll need an adapter. A number of vendors produce them; it's basically a bolt-on 15mm spacer with new studs in the larger size. It'll change your effective offset from +40 to +25, so keep that in mind when you're looking at the wheel fitment guide.
The linked thread says that an 18x8.5 +25 will stick out a lot in the front and a little in back. That may not be your best choice in wheels.
Old 09-30-2014, 01:07 PM   #3
Composite
So I guess these are not a good fit? I am still new to rim sizing so wouldnt +25 offset pop out less than +40?
Old 09-30-2014, 01:17 PM   #4
gramicci101
Off Topic
A lower offset will poke out more. 18x8.5 +40 would be a great wheel size for you if you didn't need the 5x114.3 adapter. That's what kills it. Is it possible to find those wheels in a 5x100?
Old 09-30-2014, 01:29 PM   #5
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
My front is a 18x8.5 +42 and it fits great, looks really good. +40 would be good too.
find the wheel in 5x100 or find another wheel that has a similar look. Which wheel are you looking at?
Old 09-30-2014, 01:59 PM   #6
Composite
Thank you people for the advise, I guess I will have to wait until I find another deal on rims due to the lug pattern. I found these used locally online and was going to jump on the buy but the lug pattern will not be a direct fit so I will wait for something else to come around.
Thank you to all ; )
Old 09-30-2014, 02:12 PM   #7
JonMotoring
Drives: Scion
18x8.5 +40 will work good on a stock FRS body but since the lug pattern is 5x114.3 you'll have to run a 15mm adapter which will result in +25 offset.
We are carrying some wheels that are 5x100 and the fitment is 18x9.5 +38 which works perfect on a stock FRS/BRZ body will also fit on stock or lowered FRS/BRZ suspension.
Check them out here:
JonMotoring is offline   Reply With Quote
Old 09-30-2014, 03:57 PM   #8
Composite
Those are nice rims but I am low on funds reason I am looking into used rims with tires
The Following User Says Thank You to Composite For This Useful Post:
JonMotoring (09-30-2014)
Old 09-30-2014, 04:04 PM   #9
JonMotoring
Drives: Scion
http://www.1010tires.com/Tools/Wheel-Offset-Calculator
Just did some math with that calculator and it looks like your 18x8.5 +40 with a 15mm adapter (actual offset will be 18x8.5 +25) will sit in the same outer position as the Ambit Wheel RS18 18x9.5 +38 we carry.
Circuit Sport 5x100 to 5x114.3 Adapter/Spacer (15mm)
We carry Circuit Sports 15mm 5x100 to 5x114.3 adapters. Many customer have ran these on their cars and have had great results
Old 09-30-2014, 05:15 PM   #10
dradernh
Drives: Used to Drive:Grand-Am GS #54 E36M3
Yeah, it's backwards to what we would normally think when we first encounter this stuff. Bottom line is what gramicci said:
Smaller Offset Value (including negative numbers) = Wheel Further Away from the Hub / Sticks Out More
This might be helpful: https://www.rsracing.com/tech-wheel.html#wheeltrm
dradernh is offline   Reply With Quote
Old 10-26-2014, 01:13 AM   #11
Composite
Thank you oh and those are some amazing looking wheel spacers
FS: Advan RS-D 18x8 Offset +47 Patrix Wheels and Tires 0 06-17-2014 11:47 PM
FS: xxr 527 18x8.75 +35 offset gold munjah Canada Classifieds 7 05-13-2014 08:43 PM
FS: Rota G-Force 18x8.5 +48 offset - qty 3 (three) Guaruja Wheels and Tires 21 03-31-2014 07:41 AM
Will these fit & not rub? SSR 18x8.5 49+ offset on KW CS coilovers? varun Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-01-2014 05:27 PM
18x8 37 offset kinryu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 06-29-2012 04:29 PM
