Old 09-28-2014, 04:08 PM   #1
Basket Case
Drives: 2013 Raven fr-s
What keeps the new wrx cool?
Since the new wrx shares at least some basic motor characteristics with the fa20 in our cars, it dawned upon me to ask what is keeping those cars cool? I havnt seen a discussion like this so I thought I would try and dive into it, is it the lower compression of the motor? Is the radiator larger? My warranty almost up and I think turbo is the best option but I know there are some cooling issues.
Opinions?
Basket Case is offline   Reply With Quote
Old 09-28-2014, 04:12 PM   #2
wbradley
Sarcastic SOB
wbradley's Avatar
There is a water oil cooler coil where the oil filter mounts for one thing. The rad is most likely larger as well.
Old 09-28-2014, 04:15 PM   #3
Basket Case
I knew they had the oil/water cooler, but is there something else? I know just an oil cooler on our cars isn't enough typically.
Old 09-28-2014, 04:22 PM   #4
Dipstik-sportech
Dipstik-sportech's Avatar
Better engine compartment air management, oil cooler, bigger rad, lower compression. When the engine is boosted from the factory the engineers will concentrate on cooling more
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
Calum (09-28-2014), glamcem (09-28-2014)
Old 09-28-2014, 04:28 PM   #5
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Opinions?
We need to separate here what is an issue and what is not.
Stock 86+bolt on turbo kit for street use:
Add oil cooler, you are good to go.
Stock 86 +bolt on turbo kit + heavy track use:
Oil cooler, radiator, vented hood, ensure turbo components are wrapped/coated, safae distance between fans and turbo manifold, will do.
Stock WRX for street use: factory small oil cooler, seems to be fine for street.
Stock WRX + heavy track use:
Has this even been tested? I haven't read anything on it.
My point is, you will not get into "cooling" issues unless you are doing heavy track duty which over 90% of street car owners out there are not doing.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
1stGenBRZ86 (09-29-2014), raven1231 (09-28-2014), woode (09-28-2014)
Old 09-28-2014, 05:25 PM   #6
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Its also a low mount turbo. Just like PTuning and AVO's kits.
Old 09-28-2014, 06:25 PM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
make it herra frush
Old 09-28-2014, 08:17 PM   #8
Pete156
I like to eat!
There's your answer!
Pete156 is offline   Reply With Quote
Old 09-28-2014, 08:46 PM   #9
Basket Case
I live in Florida. It's hot as hell here...cooling is always an issue here, especially in summer during traffic.
The Following User Says Thank You to Basket Case For This Useful Post:
Sportsguy83 (09-29-2014)
Old 09-28-2014, 09:00 PM   #10
Sportsguy83
Drives: Limited BRZ
I live in Miami with a top mount kit. Never had an issue with car temp on the street even on back to back to back 6 pulls with zero time to cool.
I have oil cooler, bigger rad ( not needed for street) and vented hood ( nice to have, but not required).
As long as your stock fans are working or you get a fan shroud for aftermarket fans, 100+ degree traffic are no big deal.
Sent from my SAMSUNG-SM-N900A using Tapatalk
Old 09-28-2014, 09:34 PM   #11
steve99
Opinions?
Low mount turbo
Top mount inter-cooler - not running same air through intercooler/radiator/aircond/
vented hood - for top mount intercooler
lower static compression motor
cooling/venting designed for turbo -likely larger radiator
factory oil cooler
Old 09-29-2014, 12:10 AM   #12
We did it months ago. The car overheats in stock form with enough driving.
Dipstik-sportech (09-29-2014), Sportsguy83 (09-29-2014)
Old 09-29-2014, 12:28 AM   #13
Sportsguy83
Drives: Limited BRZ
Thanks Mike. On top of things as usual.
Best way to cool you garage Border7 Other Vehicles & General Automotive Discussions 12 09-02-2014 04:09 PM
is this cool or nah ? okkoem Scion FR-S / Toyota 86 GT86 General Forum 34 08-13-2014 03:39 PM
cool!! coyot Off-Topic Lounge [WARNING: NO POLITICS] 1 12-29-2012 11:28 AM
Cool FRS ad russv Scion FR-S / Toyota 86 GT86 General Forum 1 08-21-2012 10:31 AM
Thought this was cool! so i had to get it! 86design FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 07-17-2012 10:11 PM
