Old 09-26-2014, 07:53 PM   #1
kroyoftheempire
Drives: 2013 Firestorm FR-S
Rocket Bunny Wheel Fitment
I know there is another thread on this topic and I read through it and couldnt find any real tangible information. I'm currently putting some rocket bunny fenders on my car and i will be getting spacers/wheel adapters put i until I get a new set of wheels. I wanted to put on some 17x9 up front and 17x11 in the rear. My question is what offset should I use? The front fenders whould extend about 40mm and the rear fenders about 65mm so should I have -5 offset upfront and -25 in the rear? I really dont want to put in spacers for my new wheel set
kroyoftheempire is offline   Reply With Quote
Old 09-30-2014, 11:54 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Look at what setups people are running and use www.willtheyfit.com and figure out what would give you a similar end result.
There's LOADS of info on the subject out there to use
TylerLieberman is offline   Reply With Quote
Old 10-01-2014, 03:31 AM   #3
deedz
Drives: Rocket Bunny FR-S
well there are lots of set ups you can do. Depends if you have the v1 fenders or v2 fenders. I believe v2 fenders can fit more aggressive specs but don't quote me on that...just from what Ive seen. I was going to do 18x10-10 on my set up up front and 18x11.5-24 in the rear and i know for a fact people can run more. I have seen people run 18x10.5 -16 and 18x12-28 but thats with a good stretch on the tires and decent amount of camber up front. You'll have a good amount of poke with that set up too. Don't know if you plan on stretching or doing meaty tire set ups but look up some builds or look at the speed element frs feature on stance nation, gives you exact offset of their wheels before spacers i think?
Rocket Bunny Vinyl Wrapped Build Page:
http://www.ft86club.com/forums/showthread.php?t=33573
deedz is offline   Reply With Quote
Old 12-08-2016, 02:39 PM   #4
ishfaqrubab
Drives: Toyota GT86
rocketbunny wheel fitment crisis!! I need some real advice!! :'(
ishfaqrubab is offline   Reply With Quote
Old 12-09-2016, 01:14 PM   #5
kch
Senior Misanthrope
kch's Avatar
your picture isn't visible to the rest of us here. upload to the forum itself or a site like imgur.
Old 12-09-2016, 02:22 PM   #6
ishfaqrubab
Drives: Toyota GT86
*owh! sorry for that.. https://imgur.com/a/XjOjk
Sent from my A0001 using Tapatalk
Old 12-09-2016, 04:27 PM   #7
kch
Senior Misanthrope
kch's Avatar
I'm not sure what issue you're experiencing, but at the very least it looks like you have too much front toe. I prefer 0 toe in front.
Old 12-09-2016, 05:11 PM   #8
ishfaqrubab
Drives: Toyota GT86
thanks!! currently the only issue that im facing is the clearance.. it was fine before but now when i make a full turn the tires hits the body! other then that, will a slight negetive camber on the front would effect the fitment in any possible way?? :/
Old 12-09-2016, 09:37 PM   #9
kch
Senior Misanthrope
kch's Avatar
Would need lots more info regarding your wheel and tire size, and wheel offset.
Old 12-10-2016, 12:58 AM   #10
Captain
Drives: 15' Raven FR-S
9.5 -20 front , 10.5 -40 rear. Common rocket bunny setup with slight stretch and some minimal camber.
Captain is offline   Reply With Quote
Old 12-13-2016, 08:58 PM   #11
ishfaqrubab
Drives: Toyota GT86
wheel specs 18x5 rear http://imgur.com/wnLHoCD and 18x5 front http://imgur.com/gf6hldy
Old 12-13-2016, 09:46 PM   #12
ishfaqrubab
Drives: Toyota GT86
im sorry if im wront but doesnt the report shows the front toe is set 0.00??
Old 12-14-2016, 12:24 AM   #13
ishfaqrubab
Drives: Toyota GT86
wheel specs 18x5 rear http://imgur.com/wnLHoCD and 18x5 front http://imgur.com/gf6hldy can you help me out?
Old 12-20-2016, 06:20 AM   #14
Captain
Not sure what you need help with.
Wheel specs for Rocket Bunny Fenders deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 09-02-2022 10:14 AM
Rocket bunny style DRL without the rocket bunny kit. ducky369 Cosmetic Modification (Interior/Exterior/Lighting) 0 09-22-2014 06:38 PM
Vis rocket bunny kit FrsT86-671 Cosmetic Modification (Interior/Exterior/Lighting) 3 04-27-2014 09:33 AM
Second FR-S Rocket Bunny Kit sraggs42 Scion FR-S / Toyota 86 GT86 General Forum 48 03-14-2014 06:50 PM
Rocket bunny/wheel question BadLuckZN6 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-03-2013 05:41 PM
