Drives: BRZ WR Blue, E85, Fully modified.
Driver seat problem
I'm now having a problem with my driver seat. It started to have the annoying sound after about 18,000km.
I've tried to remove all nuts and bolts underneath the seat then screw them all up tightly. However, it doesnt solve the problem. It still makes that loosen up nuts sound. Any suggestion would be helpful. I dont wanna change my seats to Recaro seats just because of having this problem. Sent from my iPhone using Tapatalk |
Drives: 2014 BRZ MT (Sold); 2006 V70R
lube the joints? Check for loose parts that could be rattling?
'14 BRZ LTD MT DGM
Señor Member
Not sure what the pics you posted have to do with your problem.... Do you have a video you can post of the sound?
Okay guys, I will lube the joint and record a video of the sound tmr morning.
Sent from my iPad using Tapatalk |
Drives: Scion FR-S, Ultramarine
what kind of sound is it?
My car has an annoying squeaky sound coming from my passenger seat. I figured out that it was the wires connected to the seat buckle. its wrapped in a type of electrical tape and when it rub it between your two fingers it creates that sound. So it gets rubbed together when youre driving |
VMFIC ORLANDO SCIKOTICS
My driver seat makes a popping noise from the bottom seat cushion. I think one of the upholstery ribs might be broken on the inside of the seat and is popping against the hog ring.
"Silence is acceptance so start talking or quit bitching!"
Drives: 2015 FR-S (6MT)
Location: Vancouver, BC. not Surrey or Richmond or Burnaby!
I think it's because you're driving from the passenger seat!
![]() But seriously, I would make sure you know that your seat is the problem. Take the seat out and get a friend to help you shake it around for a bit to see if you can hear it. If you can't find it, try to find a strip of road that it always creeks along. Take the seat out and drive it. See if the sound is still there. I had this rattle in my Civic that was due to a nut falling in a little space under the carpeting. I thought it was one of the seat bolts too. Failing that, just greasy them up real good when you put the seat back in. Last edited by jdd; 09-30-2014 at 03:40 PM. Reason: bad grammer |
Drives: Hot Lava 86 MT
I have the exact same problem!! Thought I was going nuts. Will need to look into this but it is an intermittent popping sound. Any update would be appreciated.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
| Driver seat problem | Paewrblue | Issues | Warranty | Recalls / TSB | 0 | 09-23-2014 05:29 PM |
| Seat problem | FabioGT86 | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 02-24-2014 06:22 AM |
| Cloth seat wear-Problem | BRZfan | BRZ First-Gen (2012+) — General Topics | 9 | 08-04-2013 07:44 PM |
| Cloth seat wear-Problem | BRZfan | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 9 | 08-04-2013 03:55 AM |
| Driver Seat Article... | Davyator | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 06-15-2012 09:06 PM |
