Drives: a
Guitarists? 2x12 cab fit in the back?
I know i can't fit my 4x12 cabinet in the trunk, but has anyone tried a 2x12?
Or any combos loud enough to gig with? |
Drives: 2015 Firestorm Scion FRS
a 2x12 should work if you fold the rear seats down. I never tried it as I only have 1x12 combo amp. One Fender Mustang and Orange Tiny Terror Combo!
Drives: Beige Corolla
I rented the Traynor YBA-1 reissue halfstack with the 2x12. I used our 4runner when I rented it, and tried the FRS when it was time to return it - it didn't fit in the FRS even with the seats down. Too much width. On a side note, the amp was a tone monster! Traynor makes great amps.
trick question. get a fractal axe fx and play through an frfr speaker
Drive upgrades. Don't buy them.
Drives: 2014 BRZ - 2004 GLI
Depends on the venue. I mean you could plug into the pa right?.... Jk
Depends on the cab. If it's a small 2x12 I can see maybe fanagling it in there. If it's an oversized like a bogner 2x12.... No. I'm pretty sure you could fit a hot rod deluxe and from the way it looks a twin in there. Might need help lifting it so you won't murder the bumper of you drop it. |
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
I put a Prosonic all tube 2x10 combo in the trunk the other day. I put it in parallel to the car, not sideways. It fit with a couple inches. I'd think a 2x12 would fit in the trunk sideways. It should definitely fit in the back seat. A Hardshell guitar case may fit in the trunk but the opening is a bit narrow. Got a Strat in there but my PRS case got wedged in the opening.
Getting a large cab to fit might require lowering the back seat and loading it in from the passenger door, then sliding it in to the trunk. Just make sure it clears the opening - I think it's 13"? |
Drives: BRZ Sportech
Pretty sure tube amps don't like drifting ;-)
Drives: Asphalt FRS
I have fit my Mesa 2x12 in the backseat, but never tried fitting it in the trunk since that's where I typically put my amps. I will have to take some measurements and try sliding it in the trunk. I might have to do it from the back seats thought.
There's plenty of space inside a Toyobaru, the tricky bit is finangling it through the miniscule trunk opening. Best option is to move the passenger seat forward and slide it in through the passenger door.
With the rear seats folded down of course, or like maperformance above sit it in the rear seats. With the seats up I have trouble getting a guitar case in so that would imply that maperformance has his axe riding shotgun... |
#10 |
Drives: a
Well to answer my own question...
Marshall 1936 fits perfectly (as in just). It even fits in the trunk with the seats up if you turn it around once it's in. |
#11 |
Drives: AP2 S2000, S14 240sx
#12 |
no way. what did you use for amping and cabs? thats definitely a bigger deal than the axe itself. the kemper sounds easier to use but the flexibility of the axe is crazy. i have no idea how it could get better.
#13 | |
That's just me though. When it comes to guitar, I want crystal clean jazz/fusion tones, balls to the wall metal tones, and trippy spatial effects... and I don't care for much else. haha. I could see guys that play all clean or low gain being happy with it... but the Kemper pulls off the metal tones more convincingly without sounding like the overly noise-gated, stiff, super artificial "djent" tone everyone with an Axe-FX uses. I'm surprised at the amount of guitar nerds on this forum, by the way. Didn't think there'd be any here. haha |
#14 | |
| any guitarists? | fatoni | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 03-24-2014 08:07 AM |
| I'm back | andrew | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 10-13-2013 05:27 AM |
| 18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back | KSpider | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-14-2013 07:06 PM |
| Possible trade? Nameless axle-back for Perrin Resonated Cat-back | GTB/ZR-1 | Engine, Exhaust, Bolt-Ons | 0 | 03-26-2013 01:51 PM |
| Drove the 86GT and NC miata back to back on GT5 | Hanzo | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 39 | 01-07-2012 12:56 PM |
