Old 09-12-2014, 09:40 PM   #1
ed8756
Drives: Scion FR-S, 09 jetta tdi
found water where I shouldn't
So I was installing headers and I found water in the left rear exhaust port. Head gasket? Are there any channels on the head that could leak. Looks to be quite slow as water is only going down very slowly and no smoke. Also find no evidence of water in oil. Oil level is static. Ideas? Thanks.
ed8756 is offline   Reply With Quote
Old 09-12-2014, 10:15 PM   #2
Shady195
Drives: '13 10 Series FRS #1203
How much liquid? Temperature outside? Possible it was condensation.
Shady195 is offline   Reply With Quote
Old 09-12-2014, 10:34 PM   #3
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Most likely condensation. It's not uncommon to see some condensation when doing exhaust jobs. I've seen it every time my exhaust has come off after all
Sincerely,
Zach
The Following User Says Thank You to DeliciousTuning For This Useful Post:
continuecrushing (09-16-2014)
Old 09-12-2014, 10:39 PM   #4
ed8756
Maybe like 10 to 15 drops.. wiped it away 3 times with finger to absorb. All of inside the on the one side of that left rear port. Only on the one port. The gasket also has rust on that exact location. Temp was around 98 degrees. This is the second time I have seen water in that exact location during header work.
Old 09-12-2014, 10:48 PM   #5
ed8756
@Zach nice talking to you again. Do you notice it in an isolated location like that?.
I notice it in the front pipe and over pipe and never mind but so isolated in one port freaked me out.
Old 09-13-2014, 04:07 PM   #6
Ozzman
Drives: old
Are you seeing fresh clean pure water, or coolant?
Ozzman is offline   Reply With Quote
Old 09-16-2014, 08:16 PM   #7
ed8756
That's hard to tell since it's in the exhaust port near the rear most valve. It's a bit covered in soot by the time I find it.
Old 09-16-2014, 08:20 PM   #8
ciro
Drives: Scion FR-S
do the taste test, if it is any bit of sweet you have a coolant leak.
ciro is offline   Reply With Quote
Old 09-16-2014, 08:29 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
its condensation...
Old 09-16-2014, 08:30 PM   #10
Most likely condensation like the other guys said and all cars get it. The combo of heat and condensation is why standard exhaust systems rot out so bad.
Old 09-18-2014, 09:47 PM   #11
ed8756
I think it may be condensation because there was a flange point leak at that exact location as evidenced on the gasket and flange
Old 09-18-2014, 10:00 PM   #12
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Chase it with some coolant see if it tastes the same lol
But in all seriousness its most likely condensation, the only thing i can think of otherwise would be bent gasket allowing a slight bit of water in.
Old 09-19-2014, 12:49 PM   #13
xkalelx
xkalelx's Avatar
Drives: 2013 BRZ black
Water is always a byproduct of a hydrocarbon oxidation. In this case its gasoline being oxidized in the combustion chamber. Ever noticed water dripping out of tail pipes of cars or light steam emission? That's water vapor in the exhaust gases. Manufactures typically select a low grade stainless, often feritic like a 400 series. Most aftermarket will select a higher grade stainless in the 300 series. Both will offer a much higher level of corrosion resistance over plain jane low carbon sheet steel... which would rust out almost immediately due to the corrosive conditions. More than likely you are seeing condensation around your exhaust ports.
xkalelx is offline   Reply With Quote
Old 09-19-2014, 01:16 PM   #14
Decay107
Turning is for Nerds
Decay107's Avatar
Drives: 35 characters is not enough
Probably condensation, these engines produce a surprising amount.
[ame="https://www.youtube.com/watch?v=uvZuYkh3Qb0"]Water shooting from straight piped FR-S - YouTube[/ame]
Decay107 is offline   Reply With Quote
From OPPO: Why you shouldn't modify your car for the track. rice_classic Tracking / Autocross / HPDE / Drifting 28 03-03-2014 09:42 AM
Maybe I just shouldn't own this car execoll BRZ First-Gen (2012+) — General Topics 26 12-06-2013 06:08 PM
I found a place to make water and soil into the car inside ladios Issues | Warranty | Recalls / TSB 6 02-04-2013 09:11 AM
Am i the only one who thinks carbon fiber shouldn't be in interiors? dem00n Other Vehicles & General Automotive Discussions 40 01-28-2013 07:02 PM
shouldn't have called.. shiud Scion FR-S / Toyota 86 GT86 General Forum 26 07-06-2012 10:02 PM
