Old 09-11-2014, 04:09 PM   #1
taylorsankey
Drives: 13 FRS
Muffler Removal Help
The 2 bolts connecting the muffler to midpipe wont budge. Ive got a ratchet on one side, and wrench countering the other side. Full force and wont twist. Sprayed a shit ton wd40 numerous times.
Wtf do i do...
taylorsankey is offline   Reply With Quote
Old 09-11-2014, 04:19 PM   #2
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Hammer, Never not hammer. Sounds like you could use a breaker bar or an impact wrench.
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
Old 09-11-2014, 04:33 PM   #3
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
Get a breaker bar. It's helped me a lot when I had to remove those bolts! good luck!
Jolaessss is offline   Reply With Quote
Old 09-11-2014, 04:36 PM   #4
cnk
Drives: '13 DGM BRZ Limited
You can try a penetrating lubricant like PB Blaster instead. Also, maybe start up the engine and let it heat up the exhaust a bit and then try again. When in doubt though, breaker bar or pipe extension is your friend.
cnk is offline   Reply With Quote
Old 09-11-2014, 04:54 PM   #5
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Use two wrenches instead of 1 wrench and 1 rachet. The rachet makes it a lot hard to break them loose.
Bach415 is offline   Reply With Quote
Old 09-11-2014, 05:47 PM   #6
Akari
Drives: 2013 DGM BRZ
Half a second with an impact gun or a breaker bar + mallet.
Akari is offline   Reply With Quote
Old 09-11-2014, 05:48 PM   #7
Poodles
Drives: 2015 Series.Blue
Try a real rust release penetrating lubricant... WD40 does make one, same with PB Blaster.
If all else fails, lots of heat and press a candle into the threads. The wax will flow in and lubricate.
Oh and a breaker bar.
Old 09-11-2014, 05:58 PM   #8
vroom4
Get yourself some of those cute wrist weights and strengthen up them forearms boy.
vroom4 is offline   Reply With Quote
The Following 4 Users Say Thank You to vroom4 For This Useful Post:
86-tundra (09-12-2014), Churg (09-24-2014), RevoG (09-12-2014), wparsons (09-25-2014)
Old 09-11-2014, 06:03 PM   #9
eyedeez
eyedeez's Avatar
Drives: 2014 Firestorm FR-S 6MT
I just removed the stock muffler a week ago and experienced the same problem. I used a rubber mallet with my ratchet to crack the bolts loose. A breaker bar might be a better option/investment, but sometimes you just have to use what you've got.
eyedeez is offline   Reply With Quote
Old 09-11-2014, 09:08 PM   #10
ix2vi
ix2vi's Avatar
Drives: 2013 Scion FR-S (Firestorm)
My bolts were so rusty, got me off pretty easily. Breaker bars save energy and rusty bolts lol
ix2vi is offline   Reply With Quote
Old 09-11-2014, 11:51 PM   #11
BlackBRZKnight
Drives: 2014 Crystal Black Silica
Had the same issue as you. What helped me was PB Blaster...sprayed it on, not even a minute later, bolts came loose as if they were hand tightened.
BlackBRZKnight is offline   Reply With Quote
Old 09-11-2014, 11:54 PM   #12
taylorsankey
Drives: 13 FRS
thanks for all the responses. i was bout to go and buy some pb blaster but thought aight one more try. i held the ratchet and my friend held the wrench. and i went as hard as possible and it got loose. so happy. put the nameless muffled axleback and it sounds awesome
Old 09-12-2014, 01:19 AM   #13
Kuri
Kuri's Avatar
Drives: 2014 BRZ Limited SWP
Breaker
#TrackDayBro
Kuri is offline   Reply With Quote
Old 09-12-2014, 01:31 AM   #14
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
if you plan to diy other mods, a breaker bar will come in super handy!
asdf is offline   Reply With Quote
DIY ECU removal Hawaiian DIY (Do-It-Yourself) Guides 21 02-05-2023 01:19 AM
bug removal TazMotorsports Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 30 03-31-2015 10:30 AM
Badge Removal DetroitJake Cosmetic Modification (Interior/Exterior/Lighting) 5 10-01-2013 02:35 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 05:09 PM
Clear bra removal. Any one try it? digital_assassin Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 07-13-2012 02:30 PM
