Drives: FR-S orange
Rear Lower Control arms HELP!
Need help , just installed me rear lower control arms from isc the v2 ones and install was great and everything went smooth until I lowered the car and could literally not drive over 20 because I have so much toe on both side. Positive toe on both sides to its pulling to each side. Is this shit normal, do I just need an alignment to get this fixed. What do i do, please need help. And I started at -3 camber on bc's and just had these control arms installed today about 5 months ago the coilovers were installed. I put the control arms at the lowest camber possible.
#2 | |
Drives: FR-S Whiteout
Drives: 2006 S2000
You need an alignment. When you adjust camber on the rear arms you affect the toe. Any time you adjust the camber you then have to reset the toe. Getting an alignment will fix the issue.
If you are running camber specs that are far from stock you may need aftermarket toe arms too as the stock ones don't have much adjustment to them. |
Drives: FR-S orange
But I just figure im doing something wrong, I mean I have so much toe I can't even go above 20. I guess what im looking for is if this has happened to someone else on here of if i installed them wrong. I don't know.
#5 | |
Drives: FR-S orange
Drives: '13 DGM BRZ Limited
When you lower the car, camber increases and you get toe out as well. I lowered 1" and the rear was all over the place until I got an alignment. It's been locked in ever since. Put a tiny bit of toe in on the rear and either zero toe in front or a tiny bit of toe out for more turn-in response.
#7 | |
Drives: FR-S orange
Undisputed El Presidente
Drives: Zenki 37J ZN6
When I swapped UCAs I had 1.5° toe out. Shit gets crazy when you mess with suspension bits. Lol
| Rear Lower Control Arms | toysub | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 04-24-2014 06:19 PM |
| SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout | quiet-k | Brakes, Suspension, Chassis | 8 | 03-22-2014 10:17 PM |
| WTB: Cusco Rear Lower Control Arms | that_guy | Want-To-Buy Requests | 0 | 09-30-2013 10:10 AM |
| ISC Rear Lower Control Arms | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-26-2013 09:47 AM |
| WTB - Adjustable Rear Lower Control Arms | swift996 | Want-To-Buy Requests | 0 | 06-12-2013 12:23 PM |
