Old 04-24-2014, 05:48 PM   #1
toysub
Drives: DGM
Rear Lower Control Arms
Hi all,
I don't recall seeing too much comparison info on rear lower control arms... what makes a good design and if there are any features that are specific to various uses. So many brands out there that look slightly different, but similar. Also curious if certain construction material, steel vs aluminum, is significant.
I'm installing ST coilovers for my daily driver (no track use) with 235/40-18s, but want to keep at minimum the great handling aspects of our twins. Not sure how low the drop will be, depending on the clearance I need for some driveway entries. I want to keep a balanced alignment to avoid unnecessary tire wear if possible so I would like to set the camber adjustments evenly and near stock.
Thanks in advance for any helpful comments.
toysub is offline   Reply With Quote
Old 04-24-2014, 06:03 PM   #2
Books
Books's Avatar
Drives: Ultramarine FR-S (MT)
If you're not going to do any tracking, I would go with SPC Rear LCAs and call it a day. They are cheap and do exactly what you need. They only offer 2 degrees, which should be plenty unless you're dropping real low.
Books is offline   Reply With Quote
The Following User Says Thank You to Books For This Useful Post:
toysub (04-24-2014)
Old 04-24-2014, 06:12 PM   #3
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
This is what I did and they have been excellent. The second version is what I bought. Was able to get alignment exactly to racecomp engineering's recommendations (I have konis and rce yellows).
enjoyminutemaid is offline   Reply With Quote
The Following User Says Thank You to enjoyminutemaid For This Useful Post:
toysub (04-24-2014)
Old 04-24-2014, 06:19 PM   #4
Books
Books's Avatar
Me too! But with RCE Tarmacs instead
toysub (04-24-2014)
SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout quiet-k Brakes, Suspension, Chassis 8 03-22-2014 10:17 PM
Whiteline rear lower control arms are here! Turn in Concepts Brakes, Suspension, Chassis 3 10-30-2013 11:27 AM
WTB: Cusco Rear Lower Control Arms that_guy Want-To-Buy Requests 0 09-30-2013 10:10 AM
ISC Rear Lower Control Arms FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 09-26-2013 09:47 AM
SPC Rear Adjustable Lower Control Arms Bcarlos Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 04-19-2013 10:56 PM
