Old 09-08-2014, 01:59 PM   #1
victorb
Drives: Black 86
Weitec spring by KW installation question
Hi guys, been a member and a spectator here for over a year. I am from the Philippines. Owning this car for 1.5yrs and numerous track days. Upgraded wheels and tires only. Since I've maxed out the stock suspension, I decided to upgrade to sport springs.
It's Weitec brand made by KW, lowers the car by 25/20mm front/rear with rumored spring rates of 4/5 front/rear.
I came across a problem/question regarding my newly installed springs . I've debated with the technician-installer regarding the rear spring installation. Thinking they were installed the wrong way. They installed it with the coils closer together on the bottom part (part number inverted), I am thinking it should be the other way around. Advance thank you to you guys.
Please see picture below
victorb is offline   Reply With Quote
Old 09-08-2014, 09:30 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
From what I understand it shouldn't matter. I believe the close together coils are there like a helper spring on a coilover setup, just to keep the spring seated with a lower spring rate. So they can be mounted either way without effecting anything.
1974 TA22 Celica
2013 86 GT
Old 09-08-2014, 10:10 PM   #3
wparsons
wparsons's Avatar
Yep, won't matter if it's at the top or the bottom. Those progressive coils will be totally compressed at resting ride height regardless of which end is up (on the springs, if the wheel end is up on the car things have gone horribly wrong )
The only reason it might be an issue is if they aren't seating correctly against the upper and lower seats, I can't remember which end is up on my springs (Swift sport), but I do know I installed the with the labelling right side up.
flickr
Old 09-09-2014, 12:55 AM   #4
victorb
Drives: Black 86
Thank you very much for the help and time. I can have good sleep now.
Time to hit the track soon and see if they will perform
Spring installation issues. Lucky7ance Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-03-2014 01:28 AM
weitec/kw springs johnnie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 05-07-2014 08:00 AM
Improper spring installation warning Memphis Suspension | Chassis | Brakes -- Sponsored by 949 Racing 77 03-17-2014 12:34 PM
Spring Installation Senzai Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 08-11-2013 08:19 AM
Reasonable Price for Spring Installation? tbwoodlee Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 02-14-2013 06:04 PM
