Old 09-06-2014, 02:25 AM   #1
carma143
carma143's Avatar
Drives: Toyota Highlander; Subaru BRZ (SWP)
Airplane Cockpit Switches for Limited BRZ
I was disappointed when it turned out those "switches" for the airflow settings aren't really switches.
If someone was able to make small length switches like is seen in Airplane cockpits I would buy them in a heartbeat.
Either the triangle or cylinder shaped switches would be fine. (Although I would prefer the cylinder shaped ones.)
If there ends up being a real possibility of a product like this, make sure to include the same/similar labels already present and that flipping up is on and flipping down is off.
carma143 is offline   Reply With Quote
Old 09-06-2014, 09:21 AM   #2
retoocs
You can't change the switch logic of going from momentary to latched switches. It wouldn't be hard to build a panel using momentary switches though. You just won't like the price. The regular run of the mill toggle switches are about $40 each. Switch/annunciators like for the APU in your picture are about $500+ depending on the configuration. You would also need a $400 crimp tool to crimp the contacts onto the wires.
retoocs is offline   Reply With Quote
Old 09-06-2014, 01:22 PM   #3
Pitman
Living the dream
Pitman's Avatar
Drives: Fensport AVO Turbo GT86
Not sure where you buy your toggle switches from, but just to give an idea as to the more realistic price of them:
http://www.maplin.co.uk/search?text=Toggle+Switches
Pitman is offline   Reply With Quote
Old 09-06-2014, 01:37 PM   #4
raptor87
Drives: 2013 DGM BRZ Ltd
High quality switches are more expensive
http://www.mouser.com/ProductDetail/...FWho7AodjFMAOQ
raptor87 is offline   Reply With Quote
Old 09-06-2014, 03:41 PM   #5
carma143
carma143's Avatar
Would it not be possible to make the switches give the same output for flipping up and down? In the same way, the current "switches" probably give the same output every time they are pressed down, and then the computer inside just tells the car to perform the opposite action that it is currently performing.
Of course one would have to match the physical position (up or down) of the modded switch with the function the car is currently performing (on or off).
With my limited knowledge this could work, even if a OR/AND gate is needed.
Old 09-06-2014, 04:01 PM   #6
Bigbadvoodooguru
Drives: 2014 asphalt FRS
Momentary vs latched switches. If you switched it up, when you flick the switch its like you were holding down your stock button forever. Not sure what that would do.
Bigbadvoodooguru is offline   Reply With Quote
Old 09-06-2014, 10:42 PM   #7
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Looks the the same to me...
NWFRS is offline   Reply With Quote
Old 09-07-2014, 12:14 AM   #8
retoocs
My day job involves designing aircraft electrical systems. Aircraft grade switches are way more expensive, but offer way better tactile feedback. You won't mistakenly flip a switch on.
Without having to dig through the schematic, I suspect the current switches just closes the circuit, while the computer cycles through the functions through the software. You won't be able to use a mechanical latched switch to tell the computer what to do, at least not easily.
Modern aircraft don't use too many toggle switches anymore. They all moved to push button style switches for just about everything.
They do make these in momentary, but they are $500+ each.
Old 09-08-2014, 09:13 AM   #9
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
In short:
- It's still a switch, just OP was expecting toggle switched, when in fact they're momentary switches.
- Cannot change to toggle switch unless you use some sort of complicated system or a bunch of relays to make it act like a momentary switch.
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-08-2014, 11:55 AM   #10
Gunman
Drives: 2019 Mazda Miata RF
Spyker?
Gunman is offline   Reply With Quote
Old 09-09-2014, 10:27 PM   #11
D_Thissen
D_Thissen's Avatar
Sounds right a $20 switch costs and arm and a leg because its 'aviation certified' lol
Old 09-11-2014, 04:14 AM   #12
Grymm86
Grymm86's Avatar
Drives: BRZ Limited DGM
Does anyone else remember the auto show prototypes having these style of switches? w/ curved metal bars in between them?
Grymm86 is offline   Reply With Quote
Cockpit Space Chad86 Scion FR-S / Toyota 86 GT86 General Forum 7 03-15-2014 03:24 PM
Cockpit Compilation Thread zERoTu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 09-02-2013 03:12 AM
Does anyone know where I can get switches for led? Minovsky CANADA 12 08-24-2013 09:25 PM
CNT Racing simulator cockpit, Xbox360, PS3, Forza 4 and GT5 ERZperformance Miscellaneous 11 05-12-2013 10:38 PM
Gran Turismo 5: Unseen Toyota FT-86 Cockpit Gameplay Footage KyShro Scion FR-S / Toyota 86 GT86 General Forum 28 08-19-2010 02:53 PM
