Old 09-03-2014, 11:29 AM   #1
LFA.Baby
LFA.Baby's Avatar
Drives: Frs 2014 MT whiteout
Sports Car Platform - Track Fighter
Hi fellow FT86 owner,
I've been participating a design challenge and I would like your support, click bellow to vote.
CLICK ME
Thanks for voting!!
If I win first place they will actually build my design!! Second money price, third smaller amount.
The idea was really simple, lightweight, FR, 4 cylinder engine, might be turbo charge, pretty similar to our car. Full requirements bellow the images if you feel reading.
Featured on Jalopnik LINK
Requirements
  • Design should use a 4 cylinder turbocharged engine. This platform calls for the engine to be located forward, with a center mounted transmission, and rear drive.
  • Two seats, side by side configuration
  • Track Width: Centerline of tires must be between 1295mm (51 inches) and 1549mm(61 inches) apart, side to side
  • Wheelbase: Distance between wheel axes front to rear must be between 2270mm (89 3/8 inches) and 2570mm (101 1/8 inches)
  • No Doors, no roof, climb in for ingress
  • Roll Hoop(s) behind passengers
  • Windscreen that passes at least the height of the eyes of the driver while seated
  • 4 Wheels, 17-18 inch diameter rims
  • Design should include fenders over any open wheels.
Guidelines
  • Vehicle weight for the stripped down version should be as light as possible, preferably under 1600 lbs (726 kg).
  • This car will be the basis for a platform, so there will be full bodied cars designed on this chassis in the future.
  • Track variant base model shooting for in the range of $30k (American) build cost or less.
  • Should be able to handle a large range of driver sizes comfortably
  • Car should have functional features such as cargo storage (define cubic feet of space)
  • Design should include 3 rear view mirrors, left, right, and center.
  • Independent suspension front and rear
  • Tires are 225/40R18s or 225/45R17s, depending on wheel size chosen, 17” or 18”. 457.2
  • Minimum ground clearance is 4”
  • Existing OEM headlights and taillights encouraged
  • Design includes a view showing adherence to the provided H-point diagram
  • Headlights, Taillights, Front and Rear turn signals should be shown in concept slides
  • Headlights must be at least 22” from the ground and symmetrical
  • Turn signals must be at least 15” from the ground
  • Rear turn signals must be same height as front turn signals
  • Taillamps must be at least 15” from the ground.
  • Center High mount brake light must be at least 34” from the ground.
  • Cargo space of at least 40 gallons is encouraged.
[[ ]=(86)=[ ]]
instagram - afong.86
Automotive Art
Commission me! for Virtual Tuning & Design
LFA.Baby is offline   Reply With Quote
The Following User Says Thank You to LFA.Baby For This Useful Post:
carbonBLUE (09-04-2014)
Old 09-08-2014, 11:27 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Voted for you (V1 ROUND ARCHES Version. )
I think you nailed the front end (fender forward.) The rear looks good too though I'm not feeling the breakaway bottom line of the bumper into the diffuser. The main thin *I* think is hurting this design is the side videw. The way the fenders just stop showing the chassis. It may just be the lines of the chassis' \ / \ / \ / bracing though. The front fender flows well but the rear is a bit of a wall.
Good luck, some of those 3D renders are damn impressive. Right out of a game!
Old 09-08-2014, 11:54 PM   #3
LFA.Baby
LFA.Baby's Avatar
Hey thanks for the vote.
I should have posted here before the deadline, for feedbacks.
[[ ]=(86)=[ ]]
Automotive Art
Pure Automotive Performance's White Street Fighter- 2JZ Swap - Formerly the FRSS LS2! Pure Automotive Member's Car Journals 53 03-05-2015 06:11 PM
Track-Only HPDE Brake Pad recommendations. Stock platform/calipers/rotors fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 08-20-2014 12:03 PM
Ultra Street Fighter IV Vincent Off-Topic Lounge [WARNING: NO POLITICS] 32 08-18-2014 12:06 PM
Pics & Video FRS Genesis and Rally Fighter Autocross Yruyur FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 5 10-02-2012 08:19 PM
Capcom Street Fighter Anniversary Edition FR-S w/ FiveAxis kit debuts at E3 r4m3n FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 33 06-09-2012 09:28 PM
