Old 08-30-2014, 12:15 PM   #1
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
camber plate size for coil overs
So the coil overs such as the ST/KW V3 etc that doesn't come with camber plates, expects you to purchase aftermarket plates or use the OEM top hats. In this case, does any OEM size camber plate fit the coil overs? What worried me a bit is looking at the Raceseng caster/camber plate, it has 2 different sizes for the KW V1/V3, and OEM coils. Meaning they vary in size.
I have the ST coil overs (which I heard is similar to KW V1), which camber plate size should I go for? OEM size or KW V1 size?
Currently looking at Beatrush camber plate/VooDoo13 Rear LCA combo. I contacted the vendors but with the holidays coming up, I probabily won't get an answer for a while, and I need these asap for track day!! I am assuming the beatrush camber plates are meant for the OEM size, since they do not specify any size.
I'm open to other camber plate options, and I liked the RCE plates that gives more stroke, but it states that it is not meant for street/public bumpy roads or else it may stress the parts. Only for track use recommended..
TLDR; Need camber plate for ST coil overs, not sure which size to purchase. Halp.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 08-30-2014, 08:12 PM   #2
wparsons
wparsons's Avatar
The camber plates have different "sizes" because they have the upper spring seat matched to the spring diameter. If you have ST coils, get the ones meant for KW V1/V3's.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
BRZPDX (08-31-2014)
Im buying coil overs within the next 2 days i need help deciding what coil overs Anthony7515 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 06-30-2014 08:47 AM
Im buying coil overs within the next 2 days i need help deciding what coil overs to Anthony7515 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 06-27-2014 01:00 PM
Stance Coil overs or BC coil overs ? tr1x5tuh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 36 11-26-2013 04:13 AM
XYZ Coil overs??? Juanito08 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-31-2012 09:12 PM
