Old 08-27-2014, 03:24 PM   #1
Nathan0726
Drives: 2014 scion frs monogram
Amp/Sub Install question
I just purchased a custom Sub box that will fit on the passenger side of the trunk. It comes with a 10" Kicker CVT shallow sub and an Alpine MRP-M450 amp with it. I have a 2014 FRS monogram with the stock BeSpoke head unit. Could someone tell me what all I will need to install this new sub/amp? I am a complete audio newbie. Thanks!
Nathan0726 is offline   Reply With Quote
Old 08-27-2014, 03:52 PM   #2
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
If you dont want to hack any wiring...
http://www.ft86club.com/forums/showthread.php?t=42239
Cockatoo is offline   Reply With Quote
Old 08-28-2014, 04:28 PM   #3
Terran
Terran's Avatar
Drives: Raven FR-S 6MT
If you simply just want to add in a subwoofer, I think all you should need is an 8-gauge wiring kit, given that the 2014 bespoke unit has RCA outputs in the back, and some speaker wire, if the kit doesn't come with any (mine didn't) to run from the sub to the amp.
Terran is offline   Reply With Quote
Old 08-29-2014, 05:39 AM   #4
unlimited86
Drives: s2000
I thought the 2014 bespoke don't have RCA cables.
unlimited86 is offline   Reply With Quote
Old 08-29-2014, 04:15 PM   #5
Nathan0726
You mean wiring to the stock amp or the amp that Im getting?
Old 08-30-2014, 05:02 AM   #6
Terran
Terran's Avatar
Hmm nvm, so I don't think the 2014 bespoke has RCA outputs in it, so I think you will also need a line output converter, to tap into the speakers:
[ame="http://www.amazon.com/PAC-SNI35-Adjustable-2-Channel-Converter/dp/B001EAWS3W/ref=sr_1_2?ie=UTF8&qid=1409389230&sr=8-2&keywords=line+out"]http://www.amazon.com/PAC-SNI35-Adjustable-2-Channel-Converter/dp/B001EAWS3W/ref=sr_1_2?ie=UTF8&qid=1409389230&sr=8-2&keywords=line+out[/ame]
Here's the wiring kit I'm referring to (power, ground, remote cable, etc):
[ame="http://www.amazon.com/BOSS-Audio-Gauge-Amplifier-Installation/dp/B000FKP7TY/ref=sr_1_2?ie=UTF8&qid=1409389169&sr=8-2&keywords=8+gauge+kit"]http://www.amazon.com/BOSS-Audio-Gauge-Amplifier-Installation/dp/B000FKP7TY/ref=sr_1_2?ie=UTF8&qid=1409389169&sr=8-2&keywords=8+gauge+kit[/ame]
Frs lip install question Kai Uhl Cosmetic Modification (Interior/Exterior/Lighting) 4 07-21-2014 09:39 PM
KW variant 3 install question Stale_hotdog Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 01-28-2014 12:18 PM
Fog install question Cooper911 DIY (Do-It-Yourself) Guides 4 11-17-2013 01:43 PM
Spring Install LCA To Hub Question FRS1010 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 08-14-2013 06:17 AM
K&N Drop In Install Question joelg Engine, Exhaust, Transmission 18 03-05-2013 11:29 AM
