KW variant 3 install question
In preparation before my coilovers arrive I was wondering if I need to order
the OEM Conical Washers (Subaru P.N # 20326AA000) for the front coilovers? I know the tarmacs from RCE are manufactured by KW and require these washers. Does the same hold true for the Variant 3's? I will be using the OEM tophats |
#2 | |
Drives: GBS Premium
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
yes everything is and you need to re use the tops of the OEM struts if you haven't brought camber plates.
Drives: 86
i have the OEM conical washers installed with my V3 on stock tophats.
Glorious BRZ Master Race
Drives: Subaru Libird
I called ST (who also answered my questions about KW products) and they said my ST coilovers did not need conical washers per the installation instructions. If the upper spring perches on the V3 and ST are identical (which I believe they are), you shouldn't need the washers.
A better/official answer could come from KW of North America if you call/email them (rather than getting mixed answers on this forum).
#6 | |
Drives: Attitude
#7 | |
Senior Addict
Drives: 86 GT
Anyway you shouldn't need the washers if the instructions did not call for it. |
#8 | ||
![]() The protrusion in the "composite spring cap" part of the following generic representation can be seen clearly but actual size for the FR-S spec application differs. According to the diagram, the composite spring cap reduces vibration and isolates noises associated with the chassis. And the helper spring buffers upward force against the perch to also help reduce noise/vibration (maybe better than what a conical washer alone can do).
Drives: Attitude
#10 |
Drives: Black 2013 FRS
You only need the conical washer with the whiteline strut mounts.
| Fog install question | Cooper911 | DIY (Do-It-Yourself) Guides | 4 | 11-17-2013 01:43 PM |
| Spring Install LCA To Hub Question | FRS1010 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 08-14-2013 06:17 AM |
| K&N Drop In Install Question | joelg | Engine, Exhaust, Transmission | 18 | 03-05-2013 11:29 AM |
| Suspension (Coilover) Install Question | crizkay | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 02-28-2013 09:17 AM |
| Reverse Camera - install question | Sutty | AUSTRALIA | 1 | 07-28-2012 08:40 AM |
