Old 08-27-2014, 04:24 AM   #1
Low&Slow
Low&Slow's Avatar
Drives: 10 Series #845
20mm adaptors
Hello all! I've searched through the forum, and i couldn't find anything regarding this; but do any of you guys know if you have to cut your stud down if you are to use a 20mm spacers or adapter? I know 15mm spacers/ adapters, the stud protrudes out and you would have to shave the stud down.
Low&Slow is offline   Reply With Quote
Old 08-27-2014, 04:34 AM   #2
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Check out posts number 97 through to 101 on page 5 of this thread. http://www.ft86club.com/forums/showt...t=46901&page=5
If using the stock wheels that have cavities in then you won't need to grind.
I have TRD SF2 wheels with no cavities and the 20mm ones wouldn't work as I wasn't prepared to grind the studs and even if I did the lug nuts would have sit a little proud.
nzer is offline   Reply With Quote
The Following User Says Thank You to nzer For This Useful Post:
Low&Slow (08-27-2014)
Old 08-27-2014, 02:47 PM   #3
Low&Slow
Low&Slow's Avatar
Answered my question! Thanks!
fs id1000s w pnp adaptors/gs ebc/omni 4 bar kingkai23 Engine, Exhaust, Bolt-Ons 10 06-09-2014 09:27 PM
PCD adaptors Astra^EC AFRICA 9 03-24-2014 02:50 PM
WTB: 20mm spacers teamturbo Want-To-Buy Requests 5 01-13-2014 11:12 PM
5x114 conversion adaptors GH05T Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 04-27-2013 08:35 PM
WTB: Radio wiring harnesses/adaptors JonA Audio/Visual, Electronics, Infotainment, NAV 6 04-08-2013 12:24 AM
