Old 08-19-2014, 01:44 PM   #1
Firestorm_86
Drives: FRS
Bilstein B6 B8 rear strut assembly
Hey guys,
This might be really simple, but I'm a first-timer.
There's a 'ring' around the damper shaft that the perch sits on. But I noticed the perch has a groove cut in it which the 'ring' could fit in so it doesn't slide up and down.
But I could also see the spring, when installed, applying enough pressure that the perch just sits on the 'ring'. Do I need to remove the ring, install it in the perch, then slide it down? Or does the perch just rest on the ring, on damper?
EDIT: IT HAS BEEN CONFIRMED with BILSTEIN USA that the spring seat sits on the ring.
Firestorm_86 is offline   Reply With Quote
Old 08-19-2014, 02:43 PM   #2
Firestorm_86
Drives: FRS
@FT-86 SpeedFactory and @Racecomp Engineering and @CSG Mike, any ideas?
Old 08-19-2014, 03:18 PM   #3
It looks like a snap ring. "Squeeze" the ring so it's flush on the damper, push down the perch, and it'll "pop" into place and lock the perch.
Old 08-19-2014, 03:20 PM   #4
Poodles
Drives: 2015 Series.Blue
It just rests on the ring. Bilstein has been doing this for decades (many of their shocks have multiple spots to put the ring on the shock to allow you to lower the car).
If in doubt though, there should have been directions that came with the shocks.
Old 08-19-2014, 04:19 PM   #5
Firestorm_86
Drives: FRS
It can't squeeze. It's sitting flush in the damper's groove. That said, I can pop it out, put it in the groove inside the perch, then slide the perch/ring down the damper.
I won't be able to get it off after that though. And I'd really hate for that to be the wrong way...
Yeah, I may just install it sitting on top and if it's funny/too high. I can always go back and install it with it sitting in the perch. That said, the instructions only say to compare the stock damper height vs the install height. So I guess I'll know once I have them side by side...
I've reached out to Bilstein:
wtb: rear fog light assembly chriscross_tnt Want-To-Buy Requests 6 09-02-2013 11:54 PM
eliminate rear deck popping with rear strut bar? chenshuo Issues | Warranty | Recalls / TSB 11 07-03-2013 06:44 PM
Rear Hub Assembly? SsmoothyMonster Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 02-03-2013 02:22 AM
Rear Hub Assembly? SsmoothyMonster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-03-2013 02:13 AM
Selling stock strut/spring assembly SleekMachine Brakes, Suspension, Chassis 16 12-13-2012 08:03 PM
