Old 08-15-2014, 01:38 PM   #1
Prizmatik
Drives: Manual Argento FR-S named Scyris ;)
Gas Pump Problem
Hi guys!
New to posting here but I have a problem that I can't for the life of me figure out. I have a first gen FR-S. Over the past couple months when I am at the gas station trying to fill up the tank the gas nozzle prematurely clicks. It started of doing it a couple times all the way gradually up until now a couple months later it constantly prematurely clicks several times and now gas shoots back out of the car repeatedly. It's a complete nightmare to have to get gas.
I know for a fact my tank is never filled when I stop to get gas, have tried different pumps as well as different gas stations entirely to end up with no resolve. Any ideas on what the problem is and any suggestions?
Thanks so much! :o
Sakina
Prizmatik is offline   Reply With Quote
Old 08-15-2014, 01:43 PM   #2
stugray
Drives: 2013 GBS BRZ Limited
The hose from the filler to the tank is kinked.
I have a borescope from Home depot that you could look down the tube and see.
Maybe you could stop by the local HD and ask them to demo their shelf model.
I think it's RYobi.
Old 08-15-2014, 03:07 PM   #3
Tromatic
The hose from the filler to the tank is kinked..
It's not a hose, it's a metal pipe. OP, having fuel spraying from your car is probably something you want to ask the dealer about.
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
JohnJuan (08-15-2014)
Old 08-15-2014, 04:05 PM   #4
stugray
Well that's funny since the manual calls that part a "Fuel tank to filler pipe hose" and the picture shows a hose clamp on either end of it.
cut & paste from the manual:
"13. Disconnecting the fuel tank to filler pipe hose
(1) Loosen the hose clamp, and disconnect the fuel tank to filler pipe hose."
Old 08-15-2014, 04:10 PM   #5
Timmy_Jones
Spun
Drives: 23' Supra
Yup, I would even offer to bring one of them for a quick demo. I wouldnt mess with it.
Timmy_Jones is offline   Reply With Quote
Old 08-15-2014, 04:15 PM   #6
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
Looks like warranty time.
Borla axleback exhaust * mud guards * Michelin Pilot Super Sport tires * Opti-Coat * BRZ trunk lid liner * Rexpeed Wide Mirrors (heated)
CruiseZen is offline   Reply With Quote
Old 08-15-2014, 06:07 PM   #7
extrashaky
Drives: 2014 BRZ Limited
Known issue. The rubber hose in the fuel filler has collapsed. The dealer will replace it under warranty if your mileage is still low enough.
Here's someone else with the same problem:
http://www.ft86club.com/forums/showthread.php?t=61043
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
strat61caster (08-15-2014), W2 (08-15-2014)
Old 08-15-2014, 06:41 PM   #8
Tromatic
Aha!
77213B SU00301093 HOSE, FUEL TANK TO FILLER PIPE
SCION FR-S (ZN6); BASE,HI,STD
Old 08-15-2014, 06:45 PM   #9
W2
W2's Avatar
Drives: Firestorm FR-S
I have been having the exact same issue. Pain in the ass.
W2 is offline   Reply With Quote
Old 08-15-2014, 09:29 PM   #10
Prizmatik
Thanks so much for the responses guys appreciate it much!!!
Old 08-15-2014, 09:30 PM   #11
Prizmatik
Hell yea it is!
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
AFR Problem (maybe Fuel Pump installation bad) whitefrs Engine, Exhaust, Transmission 37 08-30-2013 02:36 PM
Vac Pump sw20kosh Engine, Exhaust, Transmission 1 06-06-2013 07:46 PM
What gas do you pump? its_the_biz Scion FR-S / Toyota 86 GT86 General Forum 45 02-27-2013 11:22 PM
Be careful at the pump with E15 Thunderchicken Scion FR-S / Toyota 86 GT86 General Forum 9 08-10-2012 10:33 PM
