Old 08-11-2014, 06:27 PM   #1
monisan
Drives: 14' SWP BRZ Limited
Wiring Rydeen Duo Backup Cam to Pioneer HU
Just brought the BRZ to get my Pioneer 4000 NEX installed and was told that the Rydeen Duo won't work with my HU. Was wondering if anyone had any suggestions as to how to get it to work. Is there a wiring harness of some sort? Currently using SVXdc's wiring harness with the backup cam on the stock headunit.
Also, for the radio antenna do you suggest using Scosche LSAAB Antenna Adapter for 2002-Up Dual Lexus?
monisan is offline   Reply With Quote
Old 08-11-2014, 07:24 PM   #2
Chimera
Drives: FRS
not familiar with the cam, but based on this thread I'd say its def doable
http://www.ft86club.com/forums/showthread.php?t=34942
yes I think that's the antenna adapter you want,
see this thread:
http://www.ft86club.com/forums/showthread.php?t=16137
The Following User Says Thank You to Chimera For This Useful Post:
monisan (08-11-2014)
Old 08-15-2014, 04:36 PM   #3
cnk
Drives: '13 DGM BRZ Limited
The HU has an RCA input. You just have to connect the RCA connector from the Rydeen to the HU, then connect ground and a switched 12V+. The HU already has connections for the reverse sensor wire in it's harness. I would find a different installer that actually knows what they're doing or just install it yourself as it's not difficult if you take the time to do your research on where to tap for the different signals you need.
cnk is offline   Reply With Quote
The Following User Says Thank You to cnk For This Useful Post:
zinzan (11-24-2014)
DIY Backup camera for BeSpoke and 2014 Pioneer post_break DIY (Do-It-Yourself) Guides 48 06-01-2017 01:57 PM
Pioneer HU and Rydeen Duo Camera pauland Electronics | Audio | NAV | Infotainment 5 03-04-2014 06:20 PM
Backup Camera: Pioneer ND-BC6 vs Rydeen Duo kuro Electronics | Audio | NAV | Infotainment 1 11-18-2013 04:09 PM
HELP WIRING MY ZETA REAR BUMPER BACKUP LIGHT DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 2 08-09-2013 06:55 AM
BRZ backup camera wiring question nalc Electronics | Audio | NAV | Infotainment 1 07-26-2013 12:48 AM
