Old 07-25-2013, 08:27 AM   #1
nalc
Drives: 13 BRZ Limited 6MT GBS
BRZ backup camera wiring question
Hi folks,
Wired up a backup camera, powered it off of 12v ignition-switched and shoved a RCA female into pins 8 and 16 of the camera connector on the back of the head unit.
I didn't get any video to display.
I connected the video + to pin 8, and the video - to pin 16.
I heard somewhere that pin 15 (camera ground) should be grounded somewhere, even if you're not using the 6v power output on pin 7 to drive your camera (my camera doesn't work on 6v). Does anyone know if this is true? With just pin 8 and 16 connected, I'm not getting any video to display when I shift into reverse (I was not able to figure out how to get into the diagnostic menu), and I'm not sure whether I should try just grounding pin 15.
nalc is offline   Reply With Quote
Old 07-25-2013, 11:48 PM   #2
#944_10_Series_FRS
#944_10_Series_FRS's Avatar
Drives: 2013 10 series FRS #944
Originally Posted by nalc View Post
Hi folks,
Did you look into the DIY's section? May be the following thread might help you out;
http://www.ft86club.com/forums/showthread.php?t=17020
#944_10_Series_FRS is offline   Reply With Quote
DIY Backup camera for BeSpoke and 2014 Pioneer post_break DIY (Do-It-Yourself) Guides 48 06-01-2017 12:57 PM
Running Backup Camera Wire Tony Mac Electronics | Audio | NAV | Infotainment 9 12-04-2013 11:28 PM
HELP WIRING MY ZETA REAR BUMPER BACKUP LIGHT DealerFR-S Cosmetic Modification (Interior/Exterior/Lighting) 2 08-09-2013 05:55 AM
BRZ backup camera issues PumaSTi Electronics | Audio | NAV | Infotainment 2 06-12-2013 11:10 AM
Backup Camera Help husker741 Electronics | Audio | NAV | Infotainment 2 02-13-2013 01:04 AM
