Old 08-11-2014, 02:08 AM   #1
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
FR-S/86/BRZ Components List (Who Makes What)
I wasn't going to post this but with the recent thread debate about who did what again, I've decided to release my extensive research on who really makes what in this car. Hopefully this will make people realize that this car really is a hybrid and is more like 50% Toyota parts and 50% Subaru parts rather than the claimed 95-100% Subaru.
If anyone can add to this list, please do (with some sort of evidence).
Subaru Engine (With direction from Toyota)*
Ryobi Engine Block*
Ahresty Oil Pan
ART Pistons**
Sanjo Connecting Rods*
Taiho Engine Bearings**
Nippon Gasket**
Toyota/Denso Direct Fuel Injectors**
Denso/Kyosan Fuel Pump
OTICS Fuel Lines**
Toyoda Gosei Fuel Tank Inlet and Cap
Sakamoto Fuel Tank
Sakamoto Exhaust*
Corning Catalytic Converter
Denso Iridium Spark Plugs**
Diamond Direct Ignition Coils
Denso Starter Motor (Automatic Transmission)
Mitsubishi Electric Starter Motor (Manual Transmission)*
Mitsubishi Electric Alternator*
Mitsubishi Electric Variable Valve Timing System
Mitsuboshi Drive Belt
Yamada Water and Oil Pumps*
Nippon Thermostat
Denso A/C Components (Compressor, Condenser, HVAC Unit)
Denso Radiator and Fans
Denso Sensors
Denso ECU
Denso Airbox and Filter (Toyota Size)**
Sugitani or Sakura Metal Intake Manifold (2017+)*
Tokyo Roki Intake Manifold*
Tokyo Roki Oil Filter*
Mahle Japan Sound Creator
Kinugawa/Teito Rubber Radiator Hoses*
Sumitomo Riko/Tokai Rubber Air Conditioning Hoses
Tridon Clamps
Bridgestone Engine Mounts
Toyota/Aisin Transmission (Tuned by Subaru)**
Exedy Clutch and Flywheel
Nabtesco Clutch Cylinders*
Toyoda Gosei Clutch Line
Toyota/JTEKT Torsen Differential
NTN Driveshafts/CV Joints and Hubs
Toyota/ExxonMobil Transmission and Differential Gear Oils (Factory Fill)**
Subaru Chassis*
Subaru/Hitachi Suspension Knuckles and Arms*
Toyota/JTEKT/Denso Electric Power Steering**
Somic Stabilizer Links, Tie Rods, and Ball Joints
Showa Dampers
Sachs Dampers (Performance Package)**
Bridgestone Strut Mounts
Mitsubishi Steel Springs
Toyota ABS/EBD/VSC/TRAC Logic**
Bosch Wheel Sensors
Bosch ABS Pump
Hitachi/Tokico Brake Booster, Master Cylinder, Hoses, and Calipers
Nisshinbo Brake Pads
Jurid Brake Pads (Brembo Performance Package)
Aisin (Advics) Brake Discs
Brembo Brake Calipers and Discs (Performance Package)
Nissin Parking Brake
Hitachi Wheels
Enkei Wheels (16"/Subaru STI/Series Blue)
Michelin Tires
Yokohama Spare Tire
Pacific Industrial TPMS
Sachs/Stabilus Trunk Struts
Shiroki Trunk Lock
Aisin Door Locks
Denso Window Motors**
Asahi Glass
Toyoda Gosei Weatherstrips
Mitsuba Door Mirrors
Mitsuba Turn Signal Lamps
Koito Head/Tail Lamps
Koito Fog Lamps (2017+)
Hyundai/Mobis Fog Lamps (Scion Kit is Valeo)
Stanley Reverse Lamp
Tokai Denso License Lamp
Denso HID Ballast**
Toshiba HID Bulbs
Philips Fog Bulbs
Panasonic Battery
Panasonic (Matsushita/NAiS) and Denso Fuses/Relays
Yazaki Wiring Harness
Denso/Asmo Wiper Motor and Pump
Denso/NWB Wiper Blades and Arms
Koito Washer Fluid Reservoir
Maruko Horn
Chiyoda Pedals and Shift Lever*
LEAD Parking Brake Lever*
Shigeru Instrument Panel, Headliner, and Sun Visor*
Kasai Door Trim
Alps Door Switches*
Niles TRAC/VSC, Display, and Brake Switches*
Toyoda Gosei Steering Wheel
Toyoda Gosei Airbags
Toyota Boshoku Seats (with Moriden and Alcantara Seat Fabrics)**
Tokai Rika Seat Belts
Toyota/Tokai Rika Clockspring and Multi-Function Switches**
Toyota/Tokai Rika/Denso/Jeco Climate Control Switches**
Toyota/Tokai Rika/Denso/Aisin Immobilizer/Remote/Keyless System
Toyota/Denso/Yazaki Body Control Module**
Toyota/Pioneer Multimedia System (FR-S/86)**
Subaru/Fujitsu-Ten Multimedia System (BRZ)*
Subaru/Clarion Multimedia System (BRZ 2016+)*
Pioneer Amplifier and Speakers**
Citizen/Rhythm Watch Co. Digital Clock*
Denso/Jeco Instrument Cluster
Toyota Aerodynamics
Toyota Exterior and Interior Design (Except for the BRZ front bumper and headlamps)
*Not typical for Toyota
**Not typical for Subaru
Toyota + Subaru =
Bristecom is offline   Reply With Quote
The Following 50 Users Say Thank You to Bristecom For This Useful Post:
Adam_L (10-18-2016), AngelGT86Racer (03-14-2019), azian_advanced (08-12-2014), Brayden_23 (11-16-2015), chaoskaze (11-11-2015), Choco (12-22-2014), Dadhawk (01-29-2015), DAEMANO (11-11-2014), Decay107 (12-30-2014), dhuang (12-05-2016), DustinS (09-28-2016), DylanJZA (01-19-2023), ElijahF (11-08-2019), emutcfut (08-12-2014), FiRStsc10n (02-28-2017), FRSBRZGT86FAN (12-30-2014), FRSupra (12-22-2014), Garrett@Openflash (11-13-2014), Geese1 (04-20-2018), gkubed (01-25-2019), hamzam (11-12-2014), jebuwh (08-11-2014), Jegan_V (08-12-2014), johan (02-03-2016), juenedgi (06-25-2020), KalbiCool88 (05-23-2015), krayzie (09-26-2016), Lonewolf (08-12-2014), LucidMomentum (11-11-2014), lupindub (11-11-2015), mike_ekim1024 (05-26-2015), MisterSheep (12-10-2015), Mr.Impreza (05-22-2015), mscamp02 (12-10-2015), notout86 (10-09-2016), NyC Zn6 (12-10-2015), OnkelC (12-30-2014), Overdrive (11-29-2017), PureShield (11-13-2015), radroach (11-11-2015), RallySport (01-19-2019), Ramster (08-14-2014), sato (12-04-2016), Shourewaters (05-21-2015), tato.valverde (12-06-2016), Totality (11-17-2014), trd_kid (08-12-2014), URACK (09-28-2016), whataboutbob (02-03-2016), wulfstan (12-11-2015)
Old 08-11-2014, 02:26 AM   #2
jebuwh
Village Idiot
jebuwh's Avatar
Drives: '13 FR-S Ultramarine Manual
That was actually awesome and educational.
Thank you!
jebuwh is offline   Reply With Quote
Old 08-11-2014, 03:14 AM   #3
fusaichi_pegasus
Who makes the wheels and brakes?
fusaichi_pegasus is offline   Reply With Quote
Old 08-11-2014, 03:37 AM   #4
njccmd2002
Toyota Freak
njccmd2002's Avatar
Drives: Whiteout FRS
who makes the gas?
njccmd2002 is offline   Reply With Quote
Old 08-11-2014, 04:52 PM   #5
Bristecom
Bristecom's Avatar
Brakes are:
Bosch ABS Pump
I was not able to find who made the wheels. Probably not a popular brand name. I do know that it was Toyota who designed/styled them though.
Toyota + Subaru =
Old 08-12-2014, 12:36 AM   #6
trd_kid
13anned.
trd_kid's Avatar
Drives: Firestorm FR-S
if I had to guess I'm going to say enkei made the wheels , they are stamped made in Japan and I remember reading somewhere a while back that enkei has made oem wheels for both subaru and toyota in the past
Originally Posted by Rocket.Brz
She was not and never was 13 years old during the prom thread.
trd_kid is offline   Reply With Quote
Old 08-12-2014, 03:19 PM   #7
Bristecom
Bristecom's Avatar
They have in the past but they seem to always put their logo somewhere on it if they do and the there is no logo to be found on these wheels. So I kind of doubt it's Enkei unfortunately.
Toyota + Subaru =
Old 08-12-2014, 06:27 PM   #8
trd_kid
13anned.
trd_kid's Avatar
hmm while searching around it seems kosei is also a oem wheel maker for honda and toyota
Old 08-12-2014, 08:29 PM   #9
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Subaru makes the Scion badges.
The trunk one anyways. It's stamped Subaru on the rear of the badge. Sorry, no photo, but I think it's kind of funny.
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 08-12-2014, 11:03 PM   #10
Bristecom
Bristecom's Avatar
Just because it's stamped Subaru doesn't mean they make it. But yes, it is quite humorous that the Scion logos (on the wheel caps too) say Subaru on the back.
Toyota + Subaru =
Old 08-12-2014, 11:06 PM   #11
abraxis
Drives: many
Thanks for this!
abraxis is offline   Reply With Quote
Old 08-14-2014, 12:52 AM   #12
Bristecom
Bristecom's Avatar
Originally Posted by abraxis View Post
Thanks for this!
No problem. Welcome to the forum!
Toyota + Subaru =
Old 08-14-2014, 01:14 AM   #13
Zozr
Drives: White
I still don't understand why the Subaru owners look down on the FR-S owners. So many people on the forum are this way.
You're driving the same car buddy...
Just because the Subaru brand has more "merit" in the car world doesn't mean anything when the Scion is the same.
Zozr is offline   Reply With Quote
The Following 3 Users Say Thank You to Zozr For This Useful Post:
darthpnoy1984 (09-28-2016), DylanJZA (01-19-2023), Shourewaters (05-21-2015)
Old 11-11-2014, 12:40 PM   #14
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Great thread, great list!!
Could you possibly make the ** and * be of a different colors (As shown) so that its easier to distinguish.
Just a thought, great work regardles!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Bristecom (12-30-2014)
Ferrea's Valve components for FRS/BRZ Sportsguy83 Engine, Exhaust, Transmission 44 05-09-2014 08:46 AM
Who is running 3 way components SHIFTER Electronics | Audio | NAV | Infotainment 0 03-07-2014 10:36 PM
Koni Suspension Components dale.m Suspension | Chassis | Brakes -- Sponsored by 949 Racing 76 06-20-2013 09:00 PM
FR-S makes list to be tested for 2013 Canadian Car of the Year Award jenzan Scion FR-S / Toyota 86 GT86 General Forum 4 10-19-2012 06:59 PM
2 way possible in BRZ?? - JBL MS-62C 2 way components stevan Electronics | Audio | NAV | Infotainment 0 09-27-2012 05:35 AM
