Old 08-10-2014, 12:57 AM   #1
s207307
Drives: 2014 Scion FR-S (Raven/Monogram)
BeSpoke head unit/pt296-00140 backlight issue
I have the BeSpoke head unit (pt296-00140) on my 2014 Monogram FR-S, but it no longer emits backlighting--the orange glow behind the buttons as shown in the pic attachment (at night when I have the lights on). Does anyone know why this might be...and what wires I should test/fix in order to get the backlighting? I installed a BeatSonic backup cam and added OEM Audio Plus package, but I believe this problem existed before I performed those two upgrades.
s207307 is offline   Reply With Quote
Old 08-10-2014, 08:30 AM   #2
Chimera
Drives: FRS
IIRC illumination is typically an oj wire
Old 08-10-2014, 09:04 AM   #3
jdubious
Drives: 13 Scion FR-S
Why even try to fix it? Take it to the dealership for warranty repair.
jdubious is offline   Reply With Quote
Old 08-10-2014, 11:49 AM   #4
s207307
because I'm sure the dealership will just blame it on the aftermarket accessories--or try to fix the illumination problem and mess up my audio/cam
Old 08-10-2014, 12:58 PM   #5
Chimera
Drives: FRS
Have you tried to bypass the oem+ umbilical cord. If illumination is returned then you have identified your issue. That should be an easy check.
Old 08-10-2014, 06:42 PM   #6
s207307
I will try that...and if it turns out to be the OAP cord, I will contact OAP for support. Thanks!
NAV UNIT pt296-00140 not working rocklin662 Electronics | Audio | NAV | Infotainment 4 12-16-2013 03:13 PM
FS: BeSpoke Head Unit nocurfew Audio/Visual, Electronics, Infotainment, NAV 6 09-11-2013 08:23 PM
New standard install HU - (i believe PT546-21062) w/ NAV (PT296-00140) - Notes/observ fr3nch13 Electronics | Audio | NAV | Infotainment 3 09-09-2013 04:45 PM
[FS] BeSpoke Head Unit ProTekk Audio/Visual, Electronics, Infotainment, NAV 1 11-21-2012 12:07 AM
