CANADA Canada
Old 08-09-2014, 09:33 AM   #1
HeadBanger
HeadBanger's Avatar
Drives: '14 Subaru BRZ
Question Rust module
Anybody have a rust module on their car? Been thinking of getting one, but have no clue where to start looking really when it comes to brands and such.
I could get one through work, but the thing is it comes with all this paint protections and interior protection stuff, and I really don't need that.
Thanks
Life's too short to drive a boring car
HeadBanger is offline   Reply With Quote
Old 08-09-2014, 09:35 AM   #2
7thgear
i'm sorry, what?
7thgear's Avatar
Drives: Canada
the future of humanity
it is doomed
The Following User Says Thank You to 7thgear For This Useful Post:
Cliu91 (08-09-2014)
Old 08-09-2014, 11:38 AM   #3
HeadBanger
HeadBanger's Avatar
it is doomed
Enlighten me
Old 08-09-2014, 04:21 PM   #4
nocwage
MMTT
Drives: 2019 Subaru BRZ
Originally Posted by HeadBanger View Post
Enlighten me
Those modules are based on a technology to protect metal objects from corrosion by essentially using an electric circuit to sacrifice another metal object. (They are used effectively for things like ship hulls and metal containers)
The problem is your car is not a continuous solid piece of metal, so these devices usually don't live up to the promised protection.
nocwage is offline   Reply With Quote
The Following User Says Thank You to nocwage For This Useful Post:
ftc~brz (08-09-2014)
Old 08-09-2014, 04:29 PM   #5
nocwage
MMTT
So does it work? Well.. yes.
The same way that you could say that you could use a pickle as a lamp
[ame="https://www.youtube.com/watch?v=98p-9Ah2tF0"]Pickle Light Bulb! - YouTube[/ame]
But does it really work well enough to be worth the trouble? No.
Old 08-09-2014, 06:25 PM   #6
DimSumHero
DimSumHero's Avatar
Drives: 2015 Scion FR-S Halo
Better off just getting it undersprayed and regular rust protection.
DimSumHero is offline   Reply With Quote
The Following User Says Thank You to DimSumHero For This Useful Post:
Wilso (08-09-2014)
Old 08-09-2014, 07:42 PM   #7
wbradley
Sarcastic SOB
wbradley's Avatar
When you get one of those modules they connect a wire between major components to make sure they are in circuit such as the hood (our is aluminum, not vulnerable to corrosion). It's somewhat iffy how effective it works and probably why it's not that popular.
Old 08-09-2014, 08:42 PM   #8
Wilso
"Patience young Padawan"
Drives: 2017 Crystal White BRZ
Thanks
Don't do it. Just google "Rust Module" tests and you'll see how much of a ripoff it is.. here I actually did it for you http://rustprotectionexperiment.blogspot.ca/
Wilso is offline   Reply With Quote
Old 08-09-2014, 08:56 PM   #9
wbradley
Sarcastic SOB
wbradley's Avatar
Much to the contrary, the crude experiment indicated the module coupled subject rusted at half the rate of the control. Further, the steel in a car is protected with paint as well as galvanized in many cases so the natural rate of oxidation is much much slower. I am not sure about the paint enabling the steel to maintain a charge, though it could act as somewhat of an electrolytic insulator.
I do believe the modules work, it's just a question whether they are as effective as using rust protection spray in the long term.
They operate on the principal of the galvanic effect, whereby electrons are supplied to the metal so as not to sacrifice the electrons in the iron, thus avoiding iron oxidation.
Galvanizing steel works similarly, except the electrons are supplied in the slow degradation of zinc rather than through an electronic trickle. Iron loses electrons to oxygen in the process of oxidation, resulting in iron oxide (rust).
I deal with a galvanic treated product in my business.
Old 08-09-2014, 10:45 PM   #10
HeadBanger
HeadBanger's Avatar
If over the course of X number of years, I can greatly reduce the amount of rust that will happen to the car for a few hundred dollars, I'll do it.
Let's be real here. Subarus aren't the best cars when it comes to staying rust free.
Old 08-10-2014, 05:03 PM   #11
Wilso
You're better off getting it undercoated by Krown. The module is worthless
Old 08-15-2014, 11:38 AM   #12
bruce
Drives: 2013 frs
I GOT MY FRS OIL SPRAYED AS I THOUGHT THE COST OF THE MODULE WAS TOO HIGH. mY BROTHER AND I BOUGHT 2 2004 BUICKS NEW. I GOT MY 2004 BUICK SPRAYED AT NEW AND ITS STILL RUST FREE. MY BROTHER DIDNT AND HIS IS REALLY RUSTY..
bruce is offline   Reply With Quote
Old 08-15-2014, 12:22 PM   #13
dolo
dolo's Avatar
Drives: '13 10 Series FRS
MOAR CAPS
-Evan
dolo is offline   Reply With Quote
The Following 2 Users Say Thank You to dolo For This Useful Post:
drewbot (08-18-2014), Jay2420 (08-16-2014)
Old 08-18-2014, 10:37 AM   #14
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
@HeadBanger - DO NOT WASTE YOUR MONEY ON IT!
My old friend is a retired NRC scientist who worked on this technology for anti-corrosion in ships. He told me it works on ships and bridges immersed in a salt-water environment, but salt-water splashed on a car does not allow it to create the proper current to negate the electrical process of salt and ferrous metals.
You are better off with Krown or some other applied rust-protection. My FRS will never see snow/salt while I own it so I did nothing to it for extra rust protection. My 92 Camry, 05 Corolla and now 13 Yaris have all had dealer applied (3rd party actually apply it) corrosion protection. The Camry only had rust on the driver's side rear door and that was my fault for not cleaning out the drain holes in the bottom of the door. No other rust and it was 13 yrs old, saw every winter and had 320,000km on it when I sold it. The Corolla was totaled in 12 but it had zero rust showing anywhere.
I just can't stand the mess all of these applied coatings/treatments leave behind - either the drippy stuff on the lane-ways or the sticky stuff coating everything under the hood No way was I doing it to my FR-S!
I told off my dealer for trying to foist that snake-oil electronic rust protection crap on me and their other unsuspecting customers. $500 cash grab and they know it is bunko
Spend that $500 on a OFT or suspension upgrades or something useful instead
Cusco Suspension Braces | Eibach F & R sway bars | aFe/Takeda Intake | GReddy EVO3 | D2 RS Sport Coil-overs | TSW Interlagos | Centric Front Discs | Hawk HP+ (F) / HPS (R) | Goodrich SS brake lines | TSW & OZ Racing wheels | Continental & Hankook tires | JDP CF Front Lip | Rexspeed CF ground-effects kit | APR CF parts | Winjet headlights & fog lights | Valenti Smoked Reverse | TOM's LED taillights | CF interior upgrades | LED upgrades | and much more
FRS_Ken is offline   Reply With Quote
The Following User Says Thank You to FRS_Ken For This Useful Post:
FRSToyota86 (08-21-2014)
WTT - 2014 Scion Bespoke Nav Module for Toyota AHA Nav Module Danklvr Audio/Visual, Electronics, Infotainment, NAV 1 09-04-2014 05:57 PM
Clock module robot Want-To-Buy Requests 0 06-19-2014 06:52 PM
Nav module for 2013 FRS Drewbie Electronics | Audio | NAV | Infotainment 3 06-02-2014 02:10 PM
Led DRL Module hayleybeaners Cosmetic Modification (Interior/Exterior/Lighting) 10 02-20-2014 08:56 PM
Rust? even with rust proofing? Chinadian Issues | Warranty | Recalls / TSB 8 01-26-2013 04:15 PM
