Old 06-01-2014, 05:37 PM   #1
Drewbie
Drives: 2013 Asphalt FRS 6AT
Nav module for 2013 FRS
Ok so I want to get nav in my '13, and I'm exploring my options.
I'm wondering how much work is involved in installing the nav module?
Should I just price it at the dealer? Or is it something I could do with instructions?
Or should I just go with an aftermarket unit?
I like the ca-fi units but they're not as appealing since I have a iPhone and they're android. Any help is appreciated guys. Thanks.
Drewbie is offline   Reply With Quote
Old 06-02-2014, 10:00 AM   #2
jonzhuxD
Drives: Ultramarine FR-S
You could get the 2014 OEM Bespoke headunit. I've got one in my car and it took 10 minutes to install, remove old headunit, swap brackets, place GPS antenna and install. Works great
jonzhuxD is offline   Reply With Quote
Old 06-02-2014, 02:02 PM   #3
Drewbie
What did that run you? I've thought about doing that but thought maybe I can find a more cost effective option. The bespoke head would be nice tho. Thanks man.
Old 06-02-2014, 02:10 PM   #4
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
Or you can look for a stock BRZ unit. The only thing you'd have to wire up is the XM satellite radio antenna if you even want it. Other than that, it's just pop out a trim panel, remove 4 bolts, place GPS antennae, and swap in the unit.
aznatama is offline   Reply With Quote
Effects of LED module OURO3OROS Cosmetic Modification (Interior/Exterior/Lighting) 1 04-06-2014 04:15 AM
Led DRL Module hayleybeaners Cosmetic Modification (Interior/Exterior/Lighting) 10 02-20-2014 08:56 PM
TapTurn Module Number 6 Interior Parts (Incl. Lighting) 2 11-25-2013 06:36 PM
BRZ/FRS tap to turn module, notFRS Interior Parts (Incl. Lighting) 2 05-01-2013 03:08 AM
FS: TapTurn module KRAZYK Interior Parts (Incl. Lighting) 6 04-25-2013 02:31 PM
