| Engine Swaps Discussion of engine swaps. |
#1 | |
Drives: 2013 GBS Subaru BRZ Limited
The most interesting swap?
Group N STI transplanted into an 86 according to the article. I don't want to believe it, but the front tires definitely look like they spit dirt. How does it all fit?
![]() [ame="https://www.youtube.com/watch?v=2NvxuMGvzBw"]Toyota GT86 4x4 - YouTube[/ame] credit to: Quote:
Reverse Burnouts
Drives: 2013 Argento FRS
bump!
also very interested to see whats under the hood! EDIT: http://www.wrc.com/en/wrc/news/augus...9--12-12-.html check it out
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
#3 | |
Custom User Title
Drives: Asphalt FR-S MT
That article has nothing (relevant to the car) in it.
Drives: White 2014 Scion FRS
I'm sure with enough money and a shop it would be possible. Would probably kill the reliability of the car though as well as the resale-ability. It would be trippy if they came out with a AWD version from the factory though.
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
Scroll down this link to the Synergy V8 powered Toyota 86. A very light, very compact V8 engine built in New Zealand.
They make a small factor 2.5l V8 or a 3l V8 that is only 5mm higher. Weighs only 92kg And bolts straight in. They reckon not one hole needed to be drilled. Uses the factory ABS etc. http://autoclique.co.nz/2014/06/toyo...auckland-2014/
My fully loaded TRD86
http://www.ft86club.com/forums/showt...760#post582760 |
Drives: 2013 Raven fr-s
That motor is badass.
Junior
Drives: a car
If people can fit an LS swap into this car, I want to see the E60 M5 V10 into this car.
#8 | |
Drives: ...saving up for FRS/BRZ still
How can it be bolt on? Is there a kit for it or something? Does it use the same FA tranny? Nothing is truly "bolt in" unless it is the factory stock motor or some sort of swap kit. How much? |
#9 | |
Uses stock pretty much everything as far as I know although they had to change the drive shaft I think. If you google synergy V8 Toyota 86 you may find out more. It is being done by the guys involved in our TR86 race series.
#10 |
@Food the manufacturers website is here. An f'n amazing motor - use the desktop site.
http://www.synergypower.co.nz Not a huge amount of info on there but gives you an idea.
#11 |
Drives: Whiteout FRS, Audi A4, 135i (sold)
Older thread, but relevant information. This has been discussed before, in 2012:
http://www.ft86club.com/forums/showthread.php?t=19147
boooooooooooooooooost
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| So I didn't get a BRZ, but something interesting. | Dark | Other Vehicles & General Automotive Discussions | 54 | 04-22-2014 01:41 PM |
| Interesting graphics on a 86 | ESBjiujitsu | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 13 | 05-11-2012 11:16 PM |
| Interesting news about BBS | Esoteric | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 10 | 02-17-2012 06:10 PM |
| Why ft-86 is interesting? | NewCarInQ42011 | Scion FR-S / Toyota 86 GT86 General Forum | 69 | 11-26-2010 04:05 PM |
