Old 08-08-2014, 05:06 PM   #1
mhiscott
Drives: 2013 FRS
How to free transmission from engine
So I'm currently under my frs trying everything I can to get this damn gear box out. All hardware is out but I'm thinking the two steel dowel pins are holding the bastard together. Anyone have any tips?
mhiscott is offline   Reply With Quote
Old 08-08-2014, 05:16 PM   #2
Reaper
in orbe terrum non visi
Reaper's Avatar
Drives: violent
Probably not level. The engine mounts are super soft so I had to use two jacks to get the angle right the first time.
Old 08-08-2014, 07:13 PM   #3
mhiscott
Drives: 2013 FRS
Got it!
Old 08-08-2014, 07:22 PM   #4
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by mhiscott View Post
Got it!
I was going to say - press the clutch.
It should push it off, but you probably already unhooked the slave cylinder.
Old 08-08-2014, 08:50 PM   #5
humfrz
Then "rap" it hard with a large piece of wood ..... maybe it's just "stuck".....
humfrz
Old 08-08-2014, 08:50 PM   #6
Turdinator
Señor Member
Turdinator's Avatar
I haven't done it on my 86 yet but on some other cars I've worked on there was been slots you can get a large flat blade screw driver in to lever it apart. Is there a thread in the DIY section on this?
1974 TA22 Celica
2013 86 GT
Old 08-08-2014, 10:42 PM   #7
mhiscott
Drives: 2013 FRS
There is a diy but it doesn't mention the pain of separating the two. I ended up using map gas to heat the dowel area, then route a pry bar in from the wheel well to press apart the two right next to the dowel areas. If you do it down there you avoid marring up the aluminum where it's visible from the engine bay. Worth the extra effort as compared to prying from up top I think! Just whack the pry bar a few times with a heavy hammer and it'll come apart.
Old 08-18-2014, 02:18 PM   #8
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
for me taking it apart was the easy part, its the reinstall that was a son of a b****
DAN_BRZ is offline   Reply With Quote
Old 08-18-2014, 08:46 PM   #9
stugray
Did you try pressing the clutch?
Old 08-19-2014, 11:05 PM   #10
VacantSky
The Angry Brit
VacantSky's Avatar
Drives: 1991 E30 318iS
lol reminds me of pulling my old EJ series motor in my saabaru for sti swap. I fought that sonofabitch for a couple hours... ended up getting a small flat headed screwdriver and lightliy hammering it in between the block and the bell housing, then stepping up in sizes until I could get a large crowbar on it.
I pulled the 86's trans a few months ago too, and it came apart like a whores legs
VacantSky is offline   Reply With Quote
Old 08-19-2014, 11:27 PM   #11
litemup
Drives: around
Gladly admitting you've expanded my vocabulary
litemup is offline   Reply With Quote
Engine/Transmission noise N1rve Issues | Warranty | Recalls / TSB 48 05-06-2018 10:17 PM
For sale FA20 engine with transmission alien Engine, Exhaust, Bolt-Ons 0 10-15-2013 01:58 AM
FS:Engine and transmission 3500miles KAB-FRS Engine, Exhaust, Bolt-Ons 14 03-06-2013 01:50 PM
