Old 05-29-2012, 06:00 PM   #1
wu_dot_com
Drives: accord
is the BRZ audio compaitable with iphone 4S iOS 5.1.1
yesterday i've tried to use sync my iphone 4S with the auido unit and it was not syncing properly.
both my ipod and bluetooth were sync to the car. the blue tooth worked independently. however, the when i select to play a song in itune, the music will not play. i would then have to go to bluetooth player to play the music.
weird.
is there a way to update the soft ware on this thing?
wu_dot_com is offline   Reply With Quote
Old 05-29-2012, 06:10 PM   #2
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
According to the manual, it's only compatible with iOS 4.x or earlier, but I haven't really tried. It reads my iPod fine, but I am going to throw some songs on my iPhone and try that, as well.
Symbiont is offline   Reply With Quote
Old 05-29-2012, 06:34 PM   #3
Jayde
Jayde's Avatar
During the brief time I got to use the BRZ's audio system, I was able to dock my iPod Touch to it and stream music using the headunit no problem. This was through the USB cable. I didn't get a chance to try the Bluetooth.
According to Wikipedia, iOS 5 came out last June with a couple of patches since then, so yes, my device was running iOS 5.x.x.
Jayde is offline   Reply With Quote
Old 05-30-2012, 03:52 PM   #4
mechaghost
mechaghost's Avatar
Drives: Silver AT Limited
You can always use blutooth to stream music over. I use blutooth all the time to stream my music
mechaghost is offline   Reply With Quote
Old 05-30-2012, 04:18 PM   #5
Turbowned
Turbowned's Avatar
Oh this had better not be the case... I just traded my 3Gs for a 4s with 5.1.1!
Old 05-30-2012, 05:18 PM   #6
EmilGH
FIA Licensed Rally Driver
EmilGH's Avatar
Drives: Lots...
Send a message via ICQ to EmilGH Send a message via AIM to EmilGH Send a message via MSN to EmilGH Send a message via Yahoo to EmilGH
I can't imagine it not working with 5.1.1 …
EmilGH is offline   Reply With Quote
Old 05-30-2012, 05:44 PM   #7
Turbowned
Turbowned's Avatar
I dunno man, I've had to deal with similar issues with Audi's new MMI interface not being able to stream bluetooth audio. Older versions could do it, and certain new ones can, but the bread and butter cars can't. Was surprised it actually almost deterred some customers until they realized how awesome the cars were otherwise. It's not gonna be a dealbreaker for me either, I just find myself getting continually let down by the nav/audio unit in this car.
Old 05-31-2012, 04:16 AM   #8
touge-n00b
Storm Vanguard ONE
touge-n00b's Avatar
Drives: SCCA-HI CS-22 FRS
Both bluetooth phone and audio streaming work fine for my iPhone 4 on 5.1.1. In fact it works the the head-unit in my last car. In my last car the phone would start playing music as soon as I turned the car on, regardless if I was in the BT Audio mode or not. This new headunit doesn't do that.
touge-n00b is offline   Reply With Quote
Old 05-31-2012, 11:55 AM   #9
denkigrve
Random Internet dad
denkigrve's Avatar
Drives: 2013 FRS and 2010 Mini Cooper
iOS 5 came out in sept/oct. You can find out what os version you're ruining in Settings > General > About
denkigrve is offline   Reply With Quote
Old 05-31-2012, 12:04 PM   #10
denkigrve
Random Internet dad
denkigrve's Avatar
Factory audio has typically been a half assed effort for BT and device compatibility for iOS. They only test older devices on older software when most iOS users are on the latest major SW version.
This page shows the overall OS versioning rates http://thenextweb.com/apple/2012/03/...is-stuck-at-1/
iOS 5 has been out for plenty of time for Subaru to have tested and made sure it worked. I hope they also tested Andriod 4.x as well. Not verifying those is a huge oversight.
Old 06-02-2012, 02:24 PM   #11
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Ok - I have an iphone4 and "upgraded" to 5.1.1 (bc I have Apple TV). Sorta wishing I didn't upgrade. Anyways -
If you sync the Bluetooth from the phone to the car AND plug your phone in to the USB jack, the car will show both the phone, iPod, and Bluetooth buttons. On the iPod setting you can see the song is playing but there's no sound! If you press the Bluetooth button you get the sound, but it's very thin.
If you turn Bluetooth off on your phone, the iPod setting on the car suddenly works. And the sound quality is back.
So - there's a workaround, but you gotta decide if you're going to use Bluetooth or iPod before setting off (or change it while youre driving - at a stop light bc you have to dig into the settings on the phone, not to be done while driving).
I have been using a cassette tape adapter to play my iPod in my previous car - this is cool that you can pull up playlists, artists, albums, etc all from the car's touch screen. No need to dig into your phone. . (pressing "next" on my iPhone required me to hold the phone, unlock the screen, then aim for the "next" button all while trying to drive with one hand on the wheel - this is SO much easier and safer!)
ashtray is offline   Reply With Quote
Old 06-02-2012, 02:31 PM   #12
blu_
blu_'s Avatar
Drives: SWP BRZ LTD
I have already abandoned audio streaming via bluetooth.
Now I just plug a big usb stick into the outlet filled with music.
blu_ is offline   Reply With Quote
Old 06-02-2012, 03:21 PM   #13
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
What I've noticed is the that the on screen text message display will not work for iphone 4s 5.1.1. Another bug i noticed is if your connecting through bluetooth.. it will limit the sound.. until you get like a text message and the sound will be at full volume.
Plugging in my iphone through the usb I have no troubles with unless my bluetooth is on while i am connected. The nav system gets all confused so you have to just disable the bluetooth.
Does anyone know the specific model of the nav system? Maybe they have an update for 5.1.1
Furtive is offline   Reply With Quote
Old 06-08-2012, 01:55 PM   #14
brzg
Drives: subaru brz
just wondering if anyone has issues with the text message not syncing to the nav system? i have an iphone 4 on ios 5.1.1
brzg is offline   Reply With Quote
BRZ Navigation Audio Run Through F1point4 Electronics | Audio | NAV | Infotainment 84 10-14-2012 11:20 AM
Bespoke Audio Thoughts Dang Lad Electronics | Audio | NAV | Infotainment 19 07-17-2012 03:23 AM
Audio Options? SpeakBeck Electronics | Audio | NAV | Infotainment 13 06-04-2012 01:06 AM
Audio setup 315FR-S Electronics | Audio | NAV | Infotainment 20 05-17-2012 06:23 PM
Audio Options Aznek CANADA 2 02-26-2012 03:17 AM
