Old 08-05-2014, 07:30 PM   #1
taylorsankey
Drives: 13 FRS
CEL for a catless front pipe?
It says everywhere that you wont get a CEL for removing the secondary cat. Which makes sense cuz there arent any sensors after it.
I installed an invidia catless front pipe 10 days ago. Randomly the CEL came on. Today took it to the dealer, and they said it was cuz the removal of the secondary cat..$90 cuz aftermarket.
Is it possible to get CEL or are they bs?
taylorsankey is offline   Reply With Quote
Old 08-05-2014, 07:38 PM   #2
chas3wba0
chas3wba0's Avatar
Drives: Yes
I strongly doubt that's the cause of your CEL
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 08-05-2014, 07:46 PM   #3
fantah
fantah's Avatar
Drives: 2013 BRZ Premium Black
There's no sensor there. That's BS
fantah is offline   Reply With Quote
Old 08-06-2014, 08:13 AM   #4
Foobar
SLO NO MO
Foobar's Avatar
Sounds like BS. What code was being thrown?
Old 08-06-2014, 08:36 AM   #5
steve99
Its possible you have an exhaust leak at gaskets near the 02 sensors , and the "fresh" air getting into system on overun is triggering cel. Might have been caused when you changed front pipe. Were new gaskets used on front pipe ? did you change/remove overpipe ? assume you still have standard headers
what was code thrown up ?
Old 08-06-2014, 10:37 AM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
probably that CEL isnt relating to your front pipe. pull the code first
Old 08-06-2014, 05:09 PM   #7
taylorsankey
Drives: 13 FRS
After install, i felt no leaks. Stock headers/overpipe. New gasket. Ill find out the code tomorrow; obd2 sensor arriving tomorrow. will post
Old 08-06-2014, 05:36 PM   #8
taylorsankey
Drives: 13 FRS
Originally Posted by Marchy View Post
the dealer didn't give you the code after they pulled it?
nope
Old 08-06-2014, 05:59 PM   #9
skyloran
Honeydew old ID
skyloran's Avatar
Drives: GT86
nope
my car have N1 catless frontpipe installed for 6 months now, dont see CEL at all. i have stock header, motiv overpipe, N1 catless frtonpipe and Nameless exhaust. make sure all the bolts are tighten up well. if there is leak which most likely cause the CEL
Used to owned M3 and Lotus, but love my GT86 the most.
skyloran is offline   Reply With Quote
Old 08-07-2014, 07:19 PM   #10
taylorsankey
Drives: 13 FRS
i called for the code. they said P0420
ran my car with elm. P0420- catalyst system below threshold bank 1
what does that mean exactly and how does the car know about a catalyst problem..?
Old 08-07-2014, 10:12 PM   #11
steve99
I believe it looks at the reading from both o2 sensors one before cat and one after in headers and compares and works out if cat is working efficiently.
Either an o2 sensor has a problem (would be rear one else you car would be running crap as the front one is used for fueling) or you have exhaust leak or cat in headers is damaged/removed.
I'll put a dollar on an exhaust leak
Why buy a catless front pipe? Skeneypoo Engine, Exhaust, Transmission 12 07-22-2014 02:38 PM
FS: J2 Catless front pipe BlueDubbinTDI Engine, Exhaust, Bolt-Ons 4 03-24-2014 02:23 PM
invida catless over pipe and front pipe bnb kingkai23 NY / NJ / CT / PA 0 03-14-2014 06:32 AM
PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! Patrick@Ptuning Engine, Exhaust, Bolt-Ons 3 10-01-2013 03:16 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
