Old 08-05-2014, 06:51 PM   #1
355rockit
Drives: Sci FR-S, Fer F355, Toy Highlander
Any recommendations on a shop in San Diego to do spring swap?
I bought some used oem struts/shocks and the TRD lowering springs and I am looking for a shop in (North County) San Diego area that could swap out the springs. I plan to install the suspension myself and hold onto the original replaced suspension if I need to go back to stock, but kind of wary of the spring compressor usage. Any recommnedations?
355rockit is offline   Reply With Quote
Old 08-05-2014, 07:01 PM   #2
CSG David
CSG David's Avatar
The spring compressor is nice to have, but I took the spring off without one. I don't recommend my method, but it's possible if you know exactly what to do. With that said, most shops can do it if necessary.
Old 08-10-2014, 06:49 PM   #3
355rockit
Bought a spring compressor (single action type) from Harbour Freight. It didn't allow enough compression to allow stock spring to be removed safely since it was for longer springs. I ended up returning the spring compressor. I think I will get the springs swapped by a shop to be on the safe side.
Old 08-11-2014, 12:06 PM   #4
CSG David
CSG David's Avatar
Go to Autozone and rent out the spring compressor.
Old 08-11-2014, 02:38 PM   #5
VegasFT86
VegasFT86's Avatar
Drives: IS300, and FRS
What @CSG David said! You can rent almost any tool for Autozone or O-Riley. All you need is your ID to give to them as collateral, or they let you pay for the rent cost and return the fee when you're done.
VegasFT86 is offline   Reply With Quote
Old 08-11-2014, 02:43 PM   #6
CSG David
CSG David's Avatar
Where do you live? I'll do it ghetto style if I need to.
Paint Shop Recommendations? [GTA] Cliu91 CANADA 10 06-09-2018 01:43 PM
PDX Audio Shop Recommendations? XanRules Northwest 26 07-02-2016 07:40 PM
Body Shop recommendations?? 808FT86 Hawaii 10 05-09-2014 06:14 PM
PDX tire shop recommendations? Decay107 Northwest 9 03-13-2014 09:30 PM
Shop recommendations in Williamsburg, VA? infinite012 Mid-Atlantic 0 03-06-2013 10:15 AM
