Old 08-05-2014, 10:03 AM   #1
1Cor10:23
1Cor10:23's Avatar
Lower window strip issues
So yesterday it rained and when I started up this morning, I rolled down the window to clear some of the fine mist that was covering the windows / my view. I noticed after rolling it back up that there were 2 vertical strips that seemed untouched.
I'm guessing the lower weather strip isn't making contact? Anyone else have this issue - could it be leaking into the door?
Thanks.
Old 08-05-2014, 10:14 AM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
its the rollers leaving water on the window
Old 08-05-2014, 10:35 AM   #3
1Cor10:23
1Cor10:23's Avatar
I did the same procedure on both sides, only have some "untouched" spots on the driver side window. They're not 100% uniform either, slightly odd in shape but mostly vertical. Not sure if it's from the rollers because it was a very fine mist (from morning dew after the rain from humidity, I guess) and I assume if the roller went over it, it would look a bit different.
Visually, don't really care but is it possible for water to get into the door if the lower weatherstrip isn't making contact with the window?
Thanks!
Old 08-05-2014, 11:00 AM   #4
ZionsWrath
Thanks
ZionsWrath's Avatar
Water will always get into the door, that is why there is a plastic sheeting behind the door panel attached (sticky pasted) to the actual metal door.
pic off google
Old 08-05-2014, 11:04 AM   #5
ZionsWrath
Thanks
ZionsWrath's Avatar
another pic, you are probably seeing it like this
Old 08-05-2014, 11:10 AM   #6
1Cor10:23
1Cor10:23's Avatar
Awesome, didn't know about the sheeting. I guess there's a drain at the bottom of the door?
I've seem those roller lines before but this time, it wasn't uniform and they were closer together, like I said, it looked like the felt(?) just didn't touch the door at those spots. I'll mist some water and try and replicate / take a photo tonight.
Thanks for the pics - super helpful!
Old 08-05-2014, 02:51 PM   #7
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
yeah, look at the bottom of the door, there are many holes to let water drain.
microbionic is offline   Reply With Quote
Old 08-05-2014, 11:47 PM   #8
foompla
Drives: hot lava frs
post pics maaaaaaaaaan
foompla is offline   Reply With Quote
Window issues Oilers99 CANADA 84 11-23-2015 11:10 AM
Questions regarding dealer added lower area foglight LED strip lights NLS8520 Cosmetic Modification (Interior/Exterior/Lighting) 8 06-22-2014 11:17 AM
Window tint issues... Normal? Moshpit37 Cosmetic Modification (Interior/Exterior/Lighting) 35 09-11-2013 06:51 AM
Window issues DacoFRS CANADA 8 06-03-2013 03:14 PM
Auto up and down window Issues? CzRceCar Issues | Warranty | Recalls / TSB 3 08-07-2012 07:44 PM
