Old 08-04-2014, 08:46 PM   #1
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
fog light mod
did some good old searching on google, didnt come up with the results i wanted
have a 2014 FRS with stock fog lights (Came with car)
is there a mod or a way i can have it so the fog lights can be turned on without having to have the headlights on at the same time??
Old 08-04-2014, 11:16 PM   #2
mush
mush's Avatar
i would like to know too
Old 08-05-2014, 12:31 AM   #3
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
Not with the stock fog light harness, its powered by the headlight switch. You would have to install an aftermarket fog light harness that comes with a switch to be able to turn them off and on manually without the headlights on.
Wizardhat is offline   Reply With Quote
The Following User Says Thank You to Wizardhat For This Useful Post:
WhiteFRS69 (08-05-2014)
Old 08-05-2014, 09:16 AM   #4
WhiteFRS69
WhiteFRS69's Avatar
damn i was expecting an answer like that
i guess ill play the waiting game or ill look into making my own "harness"
Old 08-05-2014, 09:34 AM   #5
boredom.is.me
Custom User Title
boredom.is.me's Avatar
Drives: Asphalt FR-S MT
You can just hook a relay up and mount a switch to your litte side panel by the interior brightness knob.
The Following User Says Thank You to boredom.is.me For This Useful Post:
Old 08-05-2014, 01:42 PM   #6
Wizardhat
Wizardhat's Avatar
Drives: 2013 FRS
I made my own harness to tie into the OEM fog light harness using aftermarket fog light kits as I did not want just what you want. If you install a separate harness as suggested above you will run the risk of shorting or frying the OEM wiring if you do not disconnect the stock harness. Easy way to do that would be to just unplug the stock plugs and secure them so they are not bouncing around and seal the openings up on them. The Winjet fog light kit has a harness and switch that would suit your desires I believe. It is going for around $100. You would wind up with a extra set of bezels and fog lights, but it would be the most elegant solution for what you want.
Old 08-05-2014, 02:14 PM   #7
Chimera
Drives: FRS
Get this:
http://www.fteightysix.com/whats-new.../#.U-EeU4nD_IU
or this
http://www.fteightysix.com/new-produ.../#.U-EelonD_IU
and this
http://www.diodedynamics.com/store/a...iring-kit.html
tape off OEM ones securely, cover the electrical bits.
and you should be good to go.
The Following User Says Thank You to Chimera For This Useful Post:
Old 08-05-2014, 02:46 PM   #8
WhiteFRS69
WhiteFRS69's Avatar
Originally Posted by Chimera View Post
Get this:
or this
and this
big big thanks!
Zeta Performance - Lights (HID, LEDs, LED Taillights, LED Reverse Light, Trunk Light) ZetaPerformance Exterior Parts - Lighting 172 11-13-2015 10:25 AM
For Sale: Smoked/Red/Clear Reverse Light + Brake Light Bars Brand New! Vicious LED Exterior Parts (Aero, Lighting, Etc.) 9 08-25-2013 07:26 PM
**Valenti Japan LED Tail Light & Rear Bumper Reverse LED Light** nigel-jdmparts Exterior Parts - Lighting 13 04-30-2013 12:14 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
