Door Window Weather Stripping/Seal
So... over the last few months, I've noticed that the right-side window... when 100% up, was pinching the weather stripping for about a 3"-4" area. When wet, moisture would build up between the edge of the window and the seal... and with enough moisture (I'm in the PNWet), a small amount of moisture would drip into the cabin.
![]() Now the left-side window is doing the same thing... and to add to the moisture issue, there is a squeaking sound where the pinched area is on the stripping. If I take 2-3 fingers and push up hard on the area that is pinched, the squeaking stops. So... took the rig in for the 22K maintenance and had the dealership take a look at this issue. They have ordered replacement stripping (seals) and will replace the original. Stay tuned on how this plays out...
2013 Asphalt / MT
Olympia, Washington |
Drives: 2013 Asphalt 6spd
this is a somewhat common problem and is likely to do it again over time. Someone posted that the cause is that the window is angled too far in at the top which puts too much pressure on the seal when the window is rolling up. There is supposed to be a window angle adjustment screw/bolt somewhere behind the door panel. He said he adjusted the window and so did the problem.
My passenger side window has been doing the same thing. But I'm not too willing to pull off my door panel to try to fix it. I just don't use my passenger window very often. Good luck with it
Drives: 2013 DGM BRZ, 2020 C8 Corvette
common issue. mine does it too, but hasn't leaked yet.
http://www.ft86club.com/forums/showthread.php?t=68731 10 pages worth: http://www.ft86club.com/forums/showthread.php?t=11682
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
Thanks for the links to the other posts. I did a search on "Window Weather Stripping Seal" before posting... I didn't get any hits.
If MOD wants to move this post to the 10+ page post... feel free.
2013 Asphalt / MT
Drives: FR-S,GTI
Armorall it once a week. That"ll fix it.
Mine used to do this all the time but it doesn't happen anymore. It's been good for months now. |
Drives: Whiteout FR-S
Mine has leaked at car wash lol
2013 Ford Focus St
2013 Scion FR-S 2007 Honda Civic Si 2003 Acura RSX Type-S 1998 Ford Escort ZX2 |
#7 | |
Drives: 2014 BRZ Limited
https://www.google.com/webhp?sourcei...e:ft86club.com Four of the top five results are directly relevant to your question. |
Drives: 2013 FRS
You need to take some armor all and put it on a towel land apply it to that strip so it's nice and lubbed up that's what I did and it stopped
Drives: 2013 FRS
| The Following User Says Thank You to sweetfrs For This Useful Post: | Tcoat (08-16-2014) |
#10 |
Apostle
Drives: JesusMobile
I had a similar issue, my driver side door seal started leaking air and was pretty noticeable on the highway. Dealer just replaced it.
#11 |
Update...
Dealership ordered replacement rubber... took 3 days to arrive... made appointment and after dropping off the rig... job was complete in less than 3 hours. New rubber is working great... no rubbing, pinching, etc..
2013 Asphalt / MT
#12 |
Drives: 2013 raven frs
armorall will dry your rubber out over time. use a silicone based grease like shin-estu.
| The Following User Says Thank You to tonyfrs86 For This Useful Post: | Tcoat (09-17-2014) |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Trunk weather stripping? | nickmerronesucks | Issues | Warranty | Recalls / TSB | 10 | 06-16-2014 12:46 PM |
| Where to buy weather stripping? | SeattleHen | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-16-2014 02:56 AM |
| need pics of your door weather stripping! | thebucketmouse | BRZ First-Gen (2012+) — General Topics | 10 | 10-14-2013 05:01 PM |
| Small window door issue (rubber seal) | Subforever | Issues | Warranty | Recalls / TSB | 7 | 05-20-2013 05:32 AM |
