Old 10-14-2013, 11:32 AM   #1
thebucketmouse
Drives: brz
need pics of your door weather stripping!
couldnt really find a good subforum for this, so i am asking the general forum.
real quick- took the car all apart to install some audio stuff and cant figure out how the rubber weather strip on the doors goes back on. all i need are some close up pics of yours. thanks!!!
ps my car is a BRZ, probably is the same on both though
thebucketmouse is offline   Reply With Quote
Old 10-14-2013, 11:37 AM   #2
infinite012
Drives: 13 DGM BRZ Ltd
Really? You can't figure out how the rubber weather stripping goes back on the car?
infinite012 is offline   Reply With Quote
Old 10-14-2013, 02:22 PM   #3
Steve201brz
What's the point of mocking his post? He's just trying to get some help...
Anyways, I checked out my door seals at lunch. Don't have a camera (my phone is ancient) but I assume your talking about the seal that runs along the door itself...
It seems to be glued on from my quick inspection. I pulled back a part of it to try and see if it was anchored into a seam that ran along the entire seal (like the one at the top of the window). No seam as far as I could tell. Seems to be cheap OEM glue holding it onto the frame. I say this because a few spots are visibly detached, I assume from wear & tear. I pulled a little bit on one of these spots and it didn't take much at all to detach more of it from the door. Looked like they threw glue along the seal and slapped it to the door. The end of the seal that is at the top of the door seems to be anchored though... Hard to tell by just looking at it though, looks can be deceiving.
Have you looked in the audio section? Many people have taken apart the door panel and I'm sure someone has come across this before
Steve201brz is offline   Reply With Quote
Old 10-14-2013, 03:48 PM   #4
thebucketmouse
Drives: brz
Thanks for the reply! I know how to press them back onto the frame (they arent glued, they just press on) but I need to know the orientation of how they go on. Since you dont have a camera, maybe you could tell me where the ends of the strip meet? The rubber strip is one big long piece, it is not circular/connected at the ends. So where do the ends of it butt together on yours? That would help in putting mine back on.
Old 10-14-2013, 03:53 PM   #5
Flat Black VW
Flat Black VW's Avatar
Drives: 2013 Subaru BRZ
It should be one big piece however I think there is a weak point that breaks quite easily. Mine tore on the drivers side door at the base of the window towards the back of the car.
Should be pretty easy to figure out the orientation after a couple tries at most....
Flat Black VW is offline   Reply With Quote
Old 10-14-2013, 04:22 PM   #6
thebucketmouse
Drives: brz
The problem is that it will fit in just about any orientation. For it to actually be waterproof, however, I need to get it into the correct orientation. I have put it on 6 or 7 times and each time I say "hmm... that doesnt seem right". I really just need pictures.
Old 10-14-2013, 04:34 PM   #7
Muskokan
Drives: white Sport-tech
Here's my brz, have a good day!
Muskokan is offline   Reply With Quote
Old 10-14-2013, 04:40 PM   #8
thebucketmouse
Drives: brz
Sorry not that piece... I need to see the piece that goes all the way around the door frame (down the foot area, up by the windshield, over the front window and down behind it to the foot area). The piece that stays attached to the car when the door is open
Old 10-14-2013, 04:52 PM   #9
Muskokan
You picky sob.. Lol jk here ya go, just sittin in the brz waiting for someone anyways
Old 10-14-2013, 04:57 PM   #10
kakarot1657
kakarot1657's Avatar
Drives: 2013 Subaru BRZ (Galaxy Blue)
kakarot1657 is offline   Reply With Quote
Old 10-14-2013, 05:01 PM   #11
thebucketmouse
Drives: brz
Yes! Many thanks
Scion FR-S Concept First Official Pics/Videos + NYIAS Pics and Press Conference Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 856 06-14-2018 02:53 PM
All Weather Mats NedVargar Cosmetic Modification (Interior/Exterior/Lighting) 12 07-26-2013 12:42 AM
More stock pics. My Raven FR-S with graffitti background. Sick Pics Hardrock4445 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 6 11-11-2012 11:29 PM
wet weather MikesFRS Southern California 1 10-09-2012 01:17 PM
FR-S in inclement weather kounkong23 Scion FR-S / Toyota 86 GT86 General Forum 39 05-27-2011 11:16 PM
