Back in Black
Drives: Volvo S60 T6 AWD/ VW GTI PP
Hi everyone! I had a question about which would keep the engine cooler for the money: an oil cooler or a high performance radiator.
Which would you prefer? As a reference, I was looking at the Mishimoto oil cooler and radiator. Any info appreciated!
If it's Tuesday, this must be Belgium.
Drives: 2014 BRZ, 08 CBR600RR
#3 | |
I Love custom Turbo kits
Drives: Limited BRZ
What will be your intended car use? Oil cooler is better bang for buck, but pending what will be your application might need to get both.
Turning is for Nerds
Drives: 35 characters is not enough
Oil cooler definitely, for stock (and even low pressure boosted) power OEM radiator is more than adequate.
Back in Black
Thanks for the quick responses!
It will be a daily driver with regular track use.
Drives: GTS 86
Why not both? You can get a water to oil cooler kit (Cusco, factory Forester , Robispec, etc)
I was debating whether I should go Water or air cooled and decided to go water. |
Drives: 2015 Series.Blue
Oil is the only thing actively cooling the reciprocating parts in the motor, meaning it's actually more important than the coolant.
Drives: 2014 Whiteout TRD FR-S 6MT
This is actually what I was going to ask, I do a decent amount of stop/go traffic driving and freeway stuff so I was wondering if this would help / extend the life of the car
"I love dinosaurs so much that I’ve based my life on burning as much black melted dinosaur flesh as I can on a daily basis...even the screaming sound of prehistoric reptilians being burnt through any of the classic Japanese four cylinders gives me great joy."
Drives: Exige S 240
That's pretty much my use too. I think the best bang for buck in that area is the Forester oil cooler: http://www.ft86club.com/forums/showthread.php?t=50427
If, once you've installed a cooler, you feel the need for a bigger radiator you can still upgrade it. With my otherwise stock engine, I do not find it necessary at all, even on track. Both oil and water temps stay well within acceptable ranges.
#10 |
Drives: VW MK6 GTI | 13 Mustang GT
The radiator doesn't cool oil as well as the engine?
My GTI has the stock radiator and upgrade FMIC. I've done several track runs and autox's and never had an issue with oil temps.
#11 |
Drives: '13 10 Series FRS #1203
If I recall many other posting it has to do with how sealed up the engine bay is. Between the skid plates on the bottom of the car as well as the rubber seals etc on the hood the engine compartment traps heat quite well. It's especially apparent with boosted applications.
#12 |
Drives: Limited BRZ
Best bang for buck is oil cooler. Cooling oil is an issue even on stock cars. Upgraded Rad is really not that important until you go to FI or are hard core tracking it.
#13 |
Hell, I'd even draw that line at FI AND hardcore tracking it. I'm N/A with a giant exhaust manifold that passes pretty close to the radiator and I've still never seem the water above 212 while I'm trackng
| The Following User Says Thank You to Decay107 For This Useful Post: | Sportsguy83 (08-01-2014) |
| Maximal Performance FRS/BRZ Oil Cooler Kits! | Maximal | Engine, Exhaust, Bolt-Ons | 126 | 04-22-2016 12:03 PM |
| High performance Vortech at track | Sonolin | Forced Induction | 41 | 03-18-2016 07:19 PM |
| all season high performance or winter performance tires? | Aloxi | NY / NJ / CT / PA | 29 | 03-24-2015 09:23 PM |
| Rarer is Better -- High-End Aero // DSG Performance | Jason@DSG | Exterior Parts - The Rest | 88 | 10-28-2014 04:29 PM |
| What would improve overall/global cooling more: Oil Cooler or Performance Radiator? | fooddude | Tracking / Autocross / HPDE / Drifting | 22 | 04-15-2014 11:48 AM |
