Old 07-28-2014, 04:15 PM   #1
joneze93tsi
Drives: 14 BRZED
Temperature Swing = Large LTFT Swing?
Had a strange thing occur today.
Car: 14 BRZ 6MT
Mods: Only the OFT on 2.0 EL E85 map
Last drove the car when it was probably mid to low 80's out. LTFT's were 0.78 around idle and not more than 1-2% everywhere else.
Started it this morning at 68 degrees and it let out a couple pops out the exhaust and then settled into a solid idle. At idle the LTFT's are now around +13%, but not under normal driving. 2nd Start was a bit better, and now as it's warming up and I'm driving around more, it's slowly down to 10%. But it's ONLY at idle. Going down the road it's only 2-3% LTFT.
Is a +-20 degree swing enough to surprise the car?
joneze93tsi is offline   Reply With Quote
Old 07-28-2014, 05:31 PM   #2
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Nothing to worry about and totally normal. LTFT will move around quite a bit during cruise and partial load, depending on conditions. LTFT at idle aren't very important just as long as they are maxed out and you are achieving the desired AFR.
Old 07-28-2014, 05:35 PM   #3
joneze93tsi
Drives: 14 BRZED
Thanks for the quick response as usual Shiv!
Is the popping/ rough start just a product of temperature swing and E85?
Old 07-28-2014, 05:47 PM   #4
Shiv@Openflash
Drives: 2013 FRS
That's typical of E85 during cold start. It can be tuned out somewhat through custom tuning but it's a long process and most people just deal with it for the first few seconds of start-up
Old 07-28-2014, 06:27 PM   #5
joneze93tsi
Drives: 14 BRZED
Awesome thanks!
Old 07-30-2014, 11:10 PM   #6
joneze93tsi
Drives: 14 BRZED
Gotta say the car seems to run better the more tanks you put through it on E85.
Latest log:
http://datazap.me/u/joneze93tsi/e85v...ata=1-6-8-9-12
Car feels great!
brz with new kit and large wing DIG1992 Cosmetic Modification (Interior/Exterior/Lighting) 95 09-25-2014 08:08 PM
large lipped wheels? zimzum Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 02-23-2014 10:06 PM
Adjusting The Swing Length of the Door 7thgear Cosmetic Modification (Interior/Exterior/Lighting) 2 11-13-2013 06:40 PM
Cusco 'Large Throttle' ultra Engine, Exhaust, Transmission 3 09-05-2012 02:47 PM
