Old 07-28-2014, 12:26 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Which oil coolers work on a turbocharged FA20
I know there is a lot of talk about oil cooler kits out there on the market. I would just like to collect experience from posters here about what their cooler setup is and if it successfully kept the motor in a good temp range when pushing it on a road course (hpde or time trial). It would be good to note which ones (if any) did not work well at the track.
My personal reason for collecting this info: It is turning out that my turbo kit is churning out a ton of oil heat and the 7" Mocal laminova l2l oil cooler cannot deal with it.
Turbo kit:
Oil cooler kit:
Peak oil temps:
Sustained oil temps:
Peak coolant temps:
Ambient air temp at track:
Hpde or time trial:
Old 07-28-2014, 08:17 PM   #2
sw20kosh
@CSG Mike @CSG David
Is imperious still on robispec? Have you seen any other oil coolers work for turbo cars out there in your heat?
Old 07-28-2014, 08:25 PM   #3
CSG David
CSG David's Avatar
Imperious Rex is on a Koyo Radiator and Greddy Oil Cooler now + 20A SPAL fans. His Robispec radiator was leaking quite a bit so this was the quickest solution we installed for him before the time attack weekend.
For reference, the Greddy Oil Cooler is obviously designed to fit with the Greddy Turbo kit and it has worked well for now (installed just in time for this past weekend). The Jackson Racing Oil Cooler is probably still the largest by volume oil cooler available on the market.
The Following User Says Thank You to CSG David For This Useful Post:
sw20kosh (07-29-2014)
Old 07-29-2014, 10:53 AM   #4
sw20kosh
@Element Tuning how did the Perrin oil cooler fare?
Old 07-29-2014, 10:27 PM   #5
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
The Perrin cooler has been great so far but we are just still sorting this car out for racing. If it's not one thing, it's another In any event I base sucess on the oil pressure I'm seeing compared to what I had and I'm happy for now.
I feel if I need more cooling to deal with 450-500 HP I can always add one more Setrab core to my existing Perrin kit.
I was able to squeeze it all in but it was tight where my intake is.
Element Tuning is offline   Reply With Quote
Oil coolers Matey Forced Induction 37 03-13-2015 08:21 AM
FBM Tuning fixed my issue, FA20 and Visconti didn't work as well whitefrs Forced Induction 253 08-19-2013 12:39 PM
Turbocharged FA20 targeted for 270hp. Confirmed for next gen WRX Hachiroku Engine, Exhaust, Transmission 50 12-10-2011 01:23 PM
Rumor via MT's Ed Loh: Subaru to turbocharged FA20 Engine Mess11 BRZ First-Gen (2012+) — General Topics 69 12-08-2011 12:24 AM
