View Poll Results: Which winter set up?
Remount to stock and back 0 0%
Stock size steelies 3 30.00%
Smaller steelies/tires 7 70.00%
Voters: 10. You may not vote on this poll
Old 07-26-2014, 12:26 AM   #1
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Pay installation or get steelies
Okay guys, so I know it's summer now and no one wants to think about winter right now, but I want to have this figured out beforehand so there's no hassle later on. Right now I have stock sized winter tires that I had mounted on the stock wheels last winter. It worked just fine, but the problem was paying to have tires mounted twice. Depending on the outcome of this thread, I might be doing that again this winter. So the options are as follows:
Mount winters to stock wheels again.
Buy stock sized steelies, mount and keep mounted.
Sell winters, buy smaller steelies and tires. (Keeping stock because keeping all stock parts).
To shed a little more light on my problem, the original plan was to use the stock wheels as my winter wheels and buy some aftermarket wheels for everything else, but that hasn't panned out with my finances. I'm not sure when I'll be able to get the aftermarket wheels so option 1 looks to be pretty expensive. It all comes down to money really.
Nevermore is offline   Reply With Quote
Old 07-26-2014, 12:47 AM   #2
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Why don't you try buy another set of stock rims? It probably goes around for 300-400 w/ and w/o tires used depending on whom you buy it from. You can even get WRX (prior to 2015) wheels for around the same price I think.
Bach415 is offline   Reply With Quote
The Following User Says Thank You to Bach415 For This Useful Post:
Nevermore (07-26-2014)
Old 07-26-2014, 08:06 AM   #3
wparsons
wparsons's Avatar
^^ This, you can probably find a set of used stock wheels with tires for a really good price.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Bach415 (07-26-2014), Nevermore (07-26-2014)
Old 07-26-2014, 09:24 AM   #4
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
I actually found a set of stock wheels/tires locally for $200 specifically for this purpose. I think that would be the way to go.
superleggera is offline   Reply With Quote
The Following 2 Users Say Thank You to superleggera For This Useful Post:
Old 07-26-2014, 11:11 AM   #5
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
That wasn't really the plan, but looking at steelies and tires on tirerack reveals they cost a bit more than I'd hope. If I could find stock wheels that haven't had the sensors cannibalized for $200 or so that would be best. I don't need stock wheels with tires since I already have tires.
The Following User Says Thank You to Nevermore For This Useful Post:
Old 07-26-2014, 11:58 AM   #6
Black Tire
Black Tire's Avatar
Drives: Whiteout Scion FR-S
I have been researching this as well since my current snow tires are toast after two years. My finances are currently strained as well. I really want to go with the 16" option if I can possibly safe up enough money. Tire Rack sells 16x6.5 steelies for $60. I found these yesterday:
http://www.treaddepot.com/wheel/83-66527.html
Only a few $ cheaper, and do not have the correct bore size. I don't know how hub-centric rings would work with steelies.
On the same site, I found these, which I think is a better option:
http://www.treaddepot.com/wheel/si67t0440s.html
Real cheap, and about half the weight of the steelies. Also, being aluminum and winter use, you could use some cheap plastic hub-centric rings.
The Following User Says Thank You to Black Tire For This Useful Post:
Old 07-26-2014, 12:27 PM   #7
Model Citizen
Lacking brains
Drives: frz
craigslist.
it works phenomenal if you are willing to do your due diligence.
Originally Posted by cjsporl1996 View Post
If this thread is not deleted I can file a lawsuit.
Model Citizen is offline   Reply With Quote
The Following User Says Thank You to Model Citizen For This Useful Post:
wparsons (07-26-2014)
Old 07-27-2014, 01:34 PM   #8
Xinshadow
Drives: 2013 Scion FR-S Ultramarine
Originally Posted by Model Citizen View Post
craigslist.
Craigslist would be my vote as well, just do your research and don't be afraid to say no if the deal is not to your liking. In hindsight though you may have wanted to go down to a 16 inch wheel and 195 tire for snow, the narrower width really helps cut through the white stuff compared to a stock size 17. We had one of the worst winters ever in the Chicago area last year and it was a riot to glide right over the snow in my little FRS while trucks and SUVs were stuck left and right. The looks you get from other people are priceless haha. The other benefit of a downsized rim is they are stupid cheap, I found a nice set of knockoff "Sport" wheels on tire track in the right size for my Michelin X-ice IIIs for only $60/rim, which is actually cheaper than most private sale 17s in my area.
Current mods: OFT Stage 2 (w/93 oct), OFH, Perrin Resonated catback, DSS Aluminum Driveshaft, Perrin drop-in filter, Avo silicone inlet, Mishimoto catch can, Grimmspeed MCB, Perrin crank pulley, Nameless overpipe/downpipe combo, DBA slotted rotors, Ferrodo brake pads, goodrich SS brake lines, DOT5 synthetic brake fluid.
Xinshadow is offline   Reply With Quote
16x6 Silver Steelies Asphalt~86 Wheels and Tires 1 08-19-2013 12:42 PM
Pinstriped Steelies TennisHsu Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 01-21-2013 09:23 PM
anyone done steelies yet? bigjake Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 12-30-2012 09:40 AM
Winter steelies whtchocla7e Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 07-29-2012 10:21 AM
How wide do you think steelies would be OEM? RegisBou Engine, Exhaust, Transmission 23 02-24-2010 03:23 AM
