Drives: Panda FR-S
Boosted Mileage Thread
We really don't know how long our engine components will last with high forces involved with forced induction. I want to know where you guys stand as far as boosted mileage.
For me, I have roughly 36,000 SC miles and a total of 60,000+ miles on my car. All stock engine components except Fuel Injectors. I'm running the 3.48" pulley at 9psi. I redline the car a few times everyday. I have no oil catch can, so probably there is a pool of oil in my intercooler.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
![]() 242whp/197ft-lb on Mustang Dyno (91 octane water) 284whp/223ft-lb on Mustang Dyno (E85) Delicious Tuning |
Just a dude
Drives: Scion FR-S 2013
That's impressive amount of miles you've accumalated already and glad you haven't got bored looking for more that's usually the mistake some seem to take which ends that luck.
Good idea as this data is all over map in threads. Would be nice to see people rack em up with their details to as we all know reliable boost is out there and it's the kit, the install and the tune that make it so.
dying bird under the hood
Drives: 2013 SWP Limited BRZ
8000~ @12psi turbo miles 21000~ total, also redlined almost everyday
aftermarket injectors and pump, no catch can
Photo Specialist
Drives: 2013 Toyota 86 DGM 6MT
Vortech Supercharged
9PSI sealed unit Dual catch can Air to Oil Cooler 30600 mi, 20000 mi boosted
Drives: 2013 Subaru BRZ/FBM turbo flexfuel
About 18000 Miles on my car about 10k boosted at 7psi daily, 9psi option 2, an 13psi max choice... depends on the map I am running. Stock internals, FBM kit, FBM Radiator, FBM Fan shroud, Borla Exhaust from the mid Pipe back, Oil Cooler, FBM larger Oil Pan with baffle, FBM Catch Can, Flex fuel kit, Electronic Boost controller. All programmed and running off ECUTEK Tune from Delicious Tuning. 3 Variable maps through cruise control but come on you know most days after she has warmed up I'm all the way up at 13psi. It's just not fun any other way. In Denver making 357HP ... Stupid Altitude stealing My HP smell the corn fuel? so far so good
Drives: GBS Premium
4500 total miles, about 700 boosted. Innovate w/Intercooler 70mm pulley, moto intake, e85 flex fuel kit, Forester XT oil cooler, Radium Catch-Can and Moto-East tune. Car really pulls hard (and the SC sounds like a jet with the moto intake). No issues at all.
Lacking brains
Drives: frz
Kraftwerks c30 Rotorex, 9(?)psi
Diy recirc can till i melted it. Now a dity vta. Sti oil cooler tapped into radiator hoses Stock fueling Stock header 15k miles, 5 track days, shit ton of autox 33k total No issues Plenty happy with current power.
Drives: 2014 BRZ, 08 CBR600RR
JDL EL Single Scroll kit with GTX3071
10k miles total, ~2000 miles boosted Driven hard daily at 14.5 psi on E85 Tuned by HRI Tuning @jamesm Basic supporting mods: 3" Exhaust, Moto-East Flex Fuel Kit, Perrin Oil Cooler, FBM Radiator and Shroud with Spal Fans, PTP Turbo Blanket and Heat Wrap, Crawford AOS, ID1000's, AEM Failsafe and much more. No problems at all. Drivability is better than stock and it pulls pretty hard. Exedy Stage 1 clutch won't hold anymore torque, once I swap that with a stronger one ill be able to use my 16psi map and have an 18-20 psi map
Drives: Asphalt FRS
MAP turbo kit
Tuned by Jordan@MAP 8k miles boosted, 23k miles total 11psi 322whp 256wtq Dual catch can Comp stage 3 clutch Mishi radiator MAP oil cooler This is my daily driver all year round. And in MN, that means all the seasons. So far it's held up very well. Runs perfect when it's -27 below, and seems to hold up in 95 degree heat and humidity, stuck in traffic. No track time yet... |
#10 |
Sideways and Smiling!
Drives: Scion FR-S
PTuning turbo kit tuned in-house
30,002 miles total 5,000 miles with turbo kit 8,000 miles with previous vortech supercharger 10psi with exedy stage 2 clutch Car is my daily and I drive it like I stole it. |
#11 |
Boosted Member
11k miles, boosted since ~1800 miles.
Daily @ 16psi, beat the crap out of it quite often at 21psi. No issues, drive it every day - rain, snow, or shine.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG 2011 Honda CBR1000RR 2010 Subaru Impreza WRX PRM SSM |
#12 |
Drives: 2022 BRZ Limited
Mileage UPDATE
10k miles (purchased the car in March 2014) first 2k miles two track days NA 8k boosted miles about 5-6 track days with SC car is daily driven but I don't use it more than a few miles everyday so I say more than 90% of the mileage of the car is either on the track or going to (or between) track days Kraftwerks SC kit Moto-East tuned No major issues (I cracked the OEM header and blown an exhaust gasket) Running strong (knock on wood)
#13 |
building life
Drives: Raven Black, 6MT
FBM base kit
at 7PSI GT2871 Garret Turbo 550cc injectors/fuel pump 3in single outlet FBM Turbo back exhaust 4 bar base map tune 250 miles so far so good. Delicious Tune coming end of the month for 8psi, option 2 at 10psi and 12psi max |
#14 | |
Drives: White
You must be one of the highest psi daily drivers on this forum. And sometimes 21 ![]() I pray for your engine Have you dyno'd at those numbers? Edit: I had sigs off. 412 @21psi. That's crazy. |
| Boosted's BRZ | Boosted | Member's Car Journals | 41 | 11-05-2018 09:32 PM |
| Alpine's Boosted BRZ Thread | alpine | Member's Car Journals | 262 | 02-04-2015 09:31 PM |
| The Boosted Exhaust Thread | The Racers Line | Forced Induction | 49 | 06-05-2014 01:13 AM |
| cj's WRB boosted thread | cjsporl1996 | Member's Car Journals | 3 | 05-12-2014 11:47 AM |
| Boosted BRZ | mike the snake | Member's Car Journals | 3 | 12-28-2013 11:11 AM |
