Old 07-24-2014, 07:21 PM   #1
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Question Front control arm bushing noise and re-indexing
I have a squeaky noise coming from the front and I was told that this might be the front control arm bushing and they can be re-indexed.
How many of you have had the same thing happened with coilovers after a few track days? And is it really easy to re-index the bushings? I am not even familiar with the term "re-indexing" Would an aftermarket bushing (whiteline or etc) be a worthwhile upgrade ?
Thanks in advance
glamcem is offline   Reply With Quote
Old 07-25-2014, 07:53 AM   #2
wparsons
wparsons's Avatar
I'm only guessing since the term is foreign to me too, but I would think they mean loosening the bolts that hold the LCA to the subframe off a bit, then re-torquing them with the weight of the car on the wheels (sitting at normal ride height).
I did my rears when I installed my springs, but not the fronts and don't have any noises, but it's worth giving it a shot.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
glamcem (07-25-2014)
Old 07-25-2014, 01:14 PM   #3
glamcem
glamcem's Avatar
that's exactly what they said but I am not sure how it could be done since I only have jacks and jack stands so maybe my best bet is to either get some sort of ramps or take it to some place...it's really an annoying noise
Old 07-25-2014, 04:11 PM   #4
wparsons
wparsons's Avatar
You can put the jack stands under the control arms to support the car, or find a shop that'll do it for cheap (should take 5 minutes if they have an alignment hoist).
flickr
Old 07-25-2014, 04:21 PM   #5
glamcem
glamcem's Avatar
I have extra set of jack stands so I can at least give it a shot
Thanks
Perrin front control arm bushing puma Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 04-06-2014 05:18 PM
Front Control Arm Bushings Flawed - Rear Bushing Acree Issues | Warranty | Recalls / TSB 9 10-04-2013 04:19 PM
Enjuku Racing - Whiteline Control arm inner bushing (camber correction) Enjuku Racing Brakes, Suspension, Chassis 0 04-11-2013 11:21 AM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
