| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Silver AT Limited
Going to autocross the BRZ on June 10
So, I signed up for Autocross as a novice for June 10. I've never autocrossed before so I am a little bit nervous.
Do you guys have any tips for a beginner like me? Note: 1. Yes the car will be fully broken in by then. 2. I've done a 1/2 rally school and I really enjoyed that. |
Drives: 2006 Miata 5 spd
Walk with an experienced autocrosser.
Walk the course three times minimum so you can memorize the course. Do not connect the dots. Make smooth lines instead. In slalom, turn early for each cone. Your apex is right behind each cone in slalom. If you brake while turning be ready to catch the oversteer. Make sure you don't get hungry. And have fun. Watching other drivers is always helpful. If you can ride with good drivers you will see how it should be done.
2006 Miata
Because compromise ®
Drives: Red Herring
Don't get too caught up with your times. Have fun instead. I have seen people being serious at these sorts of events, they are not having fun. Enjoy thrashing you car (and i'm not being sarcastic when i say that; you are off the street, you can be as merciless as you like.)
My 4 cents. |
Conedancer
Drives: 2013 Subaru BRZ SWP
Heres something from a 4 time National Champion...http://www.tunnellracing.com/advice.html
my own advice: -1st and foremost... HAVE FUN -Learn what your car do -don't worry about anybody else -don't worry about the clock -Did I mention Have fun.. -bring a tire gauge -bring a cooler for snacks and fluids (no achohol..sorry) -Don't be afraid to ask LOTS of questions... ![]() -bring a hat, sunscreen and wear comfortable clothes -if you don't have your own helmet..they have loaners...sooo bring Fabreez.. ![]() Along with the advise From Bob...you should be fine... ![]() Bill |
You know you want it.
Drives: '13 FR-S
Keep an eye out for autocross schools. My first was a two day with nationally ranked drivers. I learned more in that school that I probably did in two seasons.
Conedancer
oh yeah...1 thing I forgot something that might help also..
Go to you-tube and just start watching Autocross Vids.. ![]() this one is me in the speedwagon..NA 2.2 Impreza wagon |
First 86
Drives: Whiteout MT FR-S
I've only been to one, but I have 3 or 4 for June planned already. I found that everyone was super helpful.
Don't shop, adopt!
Drives: 2013 DZE/01 (sold for MX5 ND1)
They're lots of fun. In addition to the advice previously posted, I'll add:
AutoX Addict
Drives: 08 Pontiac G8 GT,13 GBS BRZ Limited
1. HAVE FUN!
2. Bring snacks, lots of liquids (non-alcoholic of course ), sunscreen, and a hat/sunglasses. 3. Invest in a decent tire pressure gauge and a portable pump (you can get one from harbor freight for $9.99 that'll do the job) 4. Pump up you front tires 4-5lbs over stock to start, rears 3-4lbs. You want the car to rotate without rolling over on the side walls where you'll lose grip. Drop the pressures when begin to get too high and the car starts to slide too much. Drifting=slow, Grip=fast. 5. Walk the course as many times as you can before the race with an experienced driver. Ask them to suggest a good racing line. Usually you'll get 6-8 runs or more at regional events so take the first 2 runs at a slower pace to learn the course. 6. Don't be afraid to hit a cone in a slalom. Its part of the learning process, it happens. 7. Set small goals for yourself and don't worry about other drivers times. Ex. "I ran 1:04 first lap, my goal for today is to break 1:00" 8. Ask questions of experienced drivers. Take an instructor out riding with you for a couple runs. 9. Wear comfy shoes. You stand a lot. 10. Bring painters tape (2" is the best) 11. HAVE FUN!! To quote Chris Harris during his GT 86 review "Treat all tires as if they should die!"
2013 BRZ Limited- GBS - 6MT -VIN #0937 ~~NYR SCCA # 18 C Street R (CSR)~~ "But there’s no mistaking the noise. This car is loud, and not in a particularly nice way. There’s no crisp exhaust note, no induction wheezing. It’s just the sound of petrol exploding in a metal box." - Jeremy Clarkson Last edited by NYC BRZ; 05-28-2012 at 08:17 AM. |
#10 |
Drives: Lexus IS300 Sportcross
Some tips that I don't think were covered and some that were:
1. If the club allows it, go for rides in the passenger seats of the more experienced drivers. 2. Two pairs of shoes are probably helpful. One comfortable pair to wear when working the course, and one with thin soles when driving. 3. Be early in the slalom with your turn in. You're aiming to get the rear inside wheel next to the cone. 4. Take an instructor/experienced driver with you on all of your runs (if they're available). 5. Always be looking ahead. You should be looking at the next "element" in the course. 6. Bring painter's tape, paper towels, and some sort of cleaning fluid. 7. Lots of water, sunscreen, and a hat. 8. Bring some snacks in addition to a lunch (if they give you time for one). And, since it's so important when driving, look ahead and keep your eyes up!! The car will go where your eyes are. |
#11 |
Drives: 2013 FRS Asphalt
I have never seen a club that does not allow ride a long's. Most people will be up for it unless its the last few runs then they may say no. Try to see if you can run in the first heat if possible. Walk the course as many times as possible and take the rookie walk through. Walk the course with someone that knows more then you but then walk it by you're self as well. Walking with people is great but can get distracting. Water Water Water. Bring enough tape to tape on numbers and letters if needed. chalk the tires so you know if you are rolling over and adjust from there. Since there's is no info yet on this car.... I don't even know what to tell you to start at.
You may want to look into a co-driver who has been doing this for a while. I'm sure a few guys would be more then willing to co drive this car. This can help in a few ways. Get heat into the tires and they can help you stay on course and not get lost in the sea of cones. My local club is concrete and I run 45 psi in the front to prevent roll over. with -2 degrees of camber. On asphalt I may run less then that for more grip. These are on extreme street tires of course. I don't remember what I ran when I first started with all seasons other then it was horrid. I would tape up the car as much as possible cone marks can come out but I have had a few that does not. I broke my fender liner out the my first event. These can be replaced. so don't worry about them. Don't try and beat the people around you or you're friends that have done this before because you wont. Most new people come in thinking they are great drivers... you will be humbled if you think so. Don't be afraid to ask questions. |
#12 |
#13 |
Awesome tips! Thank you everybody! I will definitely follow each and every one of those. Especially having Fun!
#14 |
Site Moderator
Drives: Stuff
I'll be running mine on June 9th. I think my passenger seat has a list of riders that will at least equal the number of runs I'll have...
Best advice has been posted already, walk the course, keep your head (ie don't do anything stupid to save a spinning car or to cut an extra tenth, etc), ride with experienced people, etc, etc
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
| My BRZ ST* Autocross build | Scooby South | Tracking / Autocross / HPDE / Drifting | 848 | 08-14-2018 11:20 AM |
| 1st Autocross w/ my FR-S | MarkRacerX | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 24 | 06-24-2012 10:55 PM |
| Will you Autocross your 86? | Ribface | Tracking / Autocross / HPDE / Drifting | 131 | 06-22-2012 05:48 PM |
| Drove the FR-S on an Autocross course | automatic | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 4 | 06-03-2012 07:02 PM |
| FR-S at a CA Autocross | oneday | Scion FR-S / Toyota 86 GT86 General Forum | 57 | 03-26-2012 03:38 PM |
