Old 07-15-2014, 08:32 PM   #1
hypercarfanatic
Drives: Own F-150XLT, Lexus RX300
Tire/Wheel n00b
Hello All!
I know next to nothing about tires/wheels. If you would bear with me, would you mind answering a couple questions?
What is the stock tire/wheel size on the FR-S?
What does this combination of numbers/letters mean?
How do I choose the right tire?
If I want to put a specific tire on a specific wheel, how do I know it will fit?
What else would you consider "basic information" about tires/wheels that someone should know in order to be at least marginally educated about it?
Thanks for putting up with a novice!
hypercarfanatic is offline   Reply With Quote
Old 07-15-2014, 09:44 PM   #2
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
17x7" wheel. 215/45R17 tire.
What, the tire size? 215 = section width in mm. 45 = aspect ratio, meaning ratio of sidewall to section width. R = radial (all modern tires are radials). 17 = wheel diameter.
Um...can't answer that easily. Google?
Check the manufacturer's suggest wheel size for a specific tire size. Like this. Click the "specs" tab.
Read as much as you can in this section of the Tire Rack web site.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
Old 07-15-2014, 11:03 PM   #3
hypercarfanatic
--Dan
Mach V
Thanks a bunch!
Old 07-16-2014, 12:46 AM   #4
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
www.tirerack.com
Start there, read all the tire and wheel tech stuff, then come back with questions.
-alex
N00b question... please don't make fun of me. :P OnionTou Engine, Exhaust, Transmission 23 12-16-2013 05:52 PM
n00b question about exhaust tbertran Engine, Exhaust, Transmission 1 12-16-2013 02:18 PM
WTB: One FR-S OEM 17'' Wheel (don't need tire) brillo Wheels and Tires 1 09-17-2013 09:32 PM
WTB: 1 OEM wheel with or without tire #87 Wheels and Tires 11 01-31-2013 01:21 AM
N00b Question: what do you do with the OEM wheels, should you get aftermarkets? G4mb17 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 06-16-2012 05:01 AM
