Old 07-11-2014, 06:25 AM   #1
Pieczar
Drives: Toyota GT86
EU Toyota GT86 exhaust rattle problem after custom catless header
Hello to all FT-86 and BRZ owners
I got full custom exhaust right now 2,25 inch piping, front pipe catted ( high flow cat ) and resonated. Also has resonated mid pipe-small resonator.
It worked fine unitll I installed catless UEL header 4-1 which was also custom and made on JDL UEL design.
I would say quality of the components is good but current resonators,cat and muffer dosen`t work proper with very high flow from the header so the result is rattle. Sound inside the cabin is even worse than outside.
So my question is what do your suggest to change/modify/add to exhaust system to recude rattle significantly ?
Im going to try weld in a bigger resonator some where in the mid-pipe, close as possbile to muffer. If that dosen`t help I will use factory front pipe or just a factory catalyzer instead of current HFC in my front pipe.
Here`s video of sound, and pictures of exhaust,
Note that pictures are a little bit outdated cause like I said I have aftermarket custom,resonated,catted,frontpipe right now, not stock one.
https://www.facebook.com/photo.php?v=343515609135480
https://www.facebook.com/media/set/?...7352680&type=1
Pieczar is offline   Reply With Quote
Any Stock Catback Exhaust Soundclips? w/ aftermarket header + op + catless fp fooddude Engine, Exhaust, Transmission 11 08-11-2016 06:18 PM
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 01:39 PM
Anyone running 3" exhaust & catless header? RiskyTrousers Engine, Exhaust, Transmission 19 08-01-2013 09:09 AM
SRT header back exhaust catless w/ tip A serial gixxer Engine, Exhaust, Bolt-Ons 6 12-04-2012 11:00 PM
