Old 07-10-2014, 10:35 PM   #1
hmong337
Emperor JDM
hmong337's Avatar
Drives: '91 MR2 Gen3 3SGTE, '13 FRS
Water Methanol Injection? NA application.
Anybody try this? I'm interested in getting this AEM kit. I'm hoping for feedback from anybody who's done this on NA engines. It's not too popular for the NA crowd but since we run 12.5:1 compression, WMI seems fitting. If anything, I'd run it for safety than anything else.
http://www.aemelectronics.com/produc...ion-na-engines
hmong337 is offline   Reply With Quote
Old 07-10-2014, 11:06 PM   #2
s2d4
s2d4's Avatar
I use to run this until E85 came to be, biggest waste of time and money.
Old 07-11-2014, 12:06 AM   #3
xsuperbeex
Drives: Toyota Galaxy Blue Silica 86
since I dont have e85 in here.. interested..
xsuperbeex is offline   Reply With Quote
The Following User Says Thank You to xsuperbeex For This Useful Post:
hmong337 (07-11-2014)
Old 07-11-2014, 03:43 AM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
Why's that? There's a lad over here that's determined it's the next best thing since sliced bread. We don't get E85 though.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2014, 04:01 AM   #5
s2d4
s2d4's Avatar
Just a pita compared to E85.
Longer tuning time as well as getting the right nozzles for power level.
An extra system to fail although it has gotten heaps better recently, fail safe for low level etc. You are also carrying extra bottles just incase. Then you have to tie it into the ecu for a different map if no more meth mixture.
E85 has none of the above, just fill up as normal plus we have DI which has proven results by an sae research as compared to port.
However, no E85 then use meth if you will, I wouldn't bother on NA that is for sure.
The Following User Says Thank You to s2d4 For This Useful Post:
Kodename47 (07-11-2014)
Old 07-11-2014, 09:52 AM   #6
hmong337
Emperor JDM
hmong337's Avatar
Well we don't have e85 in Canada so...
Old 07-11-2014, 10:45 AM   #7
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
As someone who used to run methanol injection - don't.
It really is not worth the time and money. The stress of consistently worrying about whether your car will explode is an unneeded headache. The liability of having an explosive liquid other than gasoline in your vehicle is another deterrent (despite the 49/51 non-combustibility ratio, but why even bother putting yourself in that position in the first place).
Jyn is offline   Reply With Quote
Old 07-11-2014, 01:04 PM   #8
mike the snake
Aquamist. I've been running it on my boosted BRZ. I have a "no meth" map that pulls timing for safety, so if anything happens to the meth (clogged line/low level) it won't hurt anything.
Old 07-11-2014, 01:13 PM   #9
Ammonia
Ammonia's Avatar
Drives: Whiteout FRS, Audi A4, 135i (sold)
I ran a W/M Injection in my 135i, but only because it was tuned aggressively and I don't have E85 here. I don't see the benefits vs cost of using it in a NA car.
boooooooooooooooooost
Ammonia is offline   Reply With Quote
Old 07-11-2014, 04:58 PM   #10
hmong337
Emperor JDM
hmong337's Avatar
Well for a boosted application, I am a firm believer that it's essential! Here's my WMI kit on the mr2...
Just your simple stage 1 kit. It's merely for safety against bad gas and comes online at 10psi. My butt dyno does feel a difference in power though- with/without. I've setup an LED to the left of my boost gauge to light up when it activates. It works flawlessly even after being stored for 3 winters. Not sure where all the WMI paranoia is coming from. I know tons of people running WMI boosted and all have sung praise to it's use.
But I've never ran into anybody who has done WMI on a non-turbo application. I may be the first...? These cars get repped for being gasoline quality sensitive. The last thing I want it high cylinder temps cooking the DI seals
Old 07-12-2014, 01:04 AM   #11
s2d4
s2d4's Avatar
Do it then.
Old 07-13-2014, 12:00 AM   #12
hmong337
Emperor JDM
hmong337's Avatar
Yes, I may do it. Nothing wrong with asking around first to see if there actual people that have done it to this car- NA.
Old 07-16-2014, 12:19 PM   #13
noob and expert
Drives: None :(
What about meth+e85??
For me, there is no glide in pulse and glide :p
??? is offline   Reply With Quote
Water/methanol or flex fuel Dinko Forced Induction 28 12-17-2017 09:43 PM
PTUNING: PnP Water/Methanol Injection System w/Optional Failsafe ptuning Forced Induction 121 09-29-2017 02:01 PM
NA water meth injection? Ingen Engine, Exhaust, Transmission 26 06-03-2014 05:08 PM
water methanol injection Silverdub Forced Induction 22 07-11-2013 03:58 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-13-2013 11:03 PM
