Old 07-09-2014, 03:56 PM   #1
puravida
Drives: 14 brz, 97 nsx, 85 land cruiser
need help with a crunching sound
hi guys,
need your help with a strange noise . . .
i'm getting a brief "crunchy click" sound when initially depressing the accelerator after the car is engaged in gear. (clutch released)
the best way i can describe the sound is almost like a branch breaking. it occurs in all gears but most frequently in 6th at freeway speeds. the sound is most consistently reproducible if i let off the gas and then depress the accelerator at around 2700-3000 rpm. repeatedly doing this causes the sound to get louder.
i have had the car at the dealer and they are unable to determine the source of the sound, they have assured me that its nothing serious. i'm just not convinced . . .
i'm grateful for your help.
puravida is offline   Reply With Quote
Old 07-09-2014, 04:04 PM   #2
chicagokid
Club Member
chicagokid's Avatar
Drives: 2014 Asphalt FR-S Monogram 6MT
i've noticed this too. same sound, but like aluminium shaking another aluminium.
chicagokid is offline   Reply With Quote
Old 07-09-2014, 08:44 PM   #3
Dephective
Drives: '13 Whiteout FRS
Is it right after upshift, release clutch, get back on throttle? I get a brief aluminum on aluminum sound right being a little aggressive with throttle after upshifting or when aggressive throttle blipping for rev match down shifts.
Previous:
'01 Accord-daily
'93 Rx7-fire breathing track monster 545hp 397tq 2300lb.
'06 Mazdaspeed6 one helluva love-hate relationship
Dephective is offline   Reply With Quote
Old 07-09-2014, 11:17 PM   #4
puravida
it seems to be independent of shifting . . . the times i notice it the most are on the freeway and i let off the gas for whatever reason then start the accelerate . . . i hear a crunch. it is consistently reproducible by doing this, i.e. letting off the gas completely and then gently accelerating. it occurs just as i hit the throttle lasting a second or so.
Old 08-11-2014, 01:32 AM   #5
wmak
Drives: Series Blue BRZ
Just got hold of my series blue two weeks ago and I also I experience this same problem. Depressing the accelerator more smoothly helps in lower gears, but I always experience it when letting off the gas then engaging again while in the higher gears. Any luck with finding a solution or what is causing this noise?
wmak is offline   Reply With Quote
Old 08-12-2014, 10:31 AM   #6
puravida
No luck with a solution … had the car at the dealer several times with no clear explanation. The most recent dealer explanation is that the car is "knocking" secondary to using 91 octane as opposed to the recommended 93 which we can't get. I'm not sure I buy that … it's such a strange noise. Let me know if you find something out with yours… thanks
Old 08-12-2014, 07:16 PM   #7
wmak
Will do. Going to take it into the dealer after I get go to the DMV for CA registration.
Popping, Crunching and Creaking Noise MyEvilMonkeys Suspension | Chassis | Brakes -- Sponsored by 949 Racing 22 07-22-2020 12:50 PM
South Sound Summer Jam 2013 | 8.18.13 | South Sound Speedway RussellM Northwest 13 09-05-2013 09:57 AM
Amp no sound asher187 Electronics | Audio | NAV | Infotainment 8 08-15-2013 06:03 PM
Sound - ASL ScottKR Electronics | Audio | NAV | Infotainment 0 07-01-2013 10:34 AM
What should the FR-S sound like? 1660 Off-Topic Lounge [WARNING: NO POLITICS] 26 07-31-2011 01:33 AM
