Old 05-25-2012, 10:32 PM   #1
dsgerbc
Drives: BRZ(sold), STI
tire deformation question.
So I test-fitted a set of 04 STI rims (17x7.5 +53) that I have some rubber (old re01-r 235/40) mounted on that needs to be finished off on track/autox.
It fits but I can barely squeeze my fingertips between sidewall and the spring seat (see pic).
My question is - by how much the tire could deflect up top while cornering?
dsgerbc is offline   Reply With Quote
The Following User Says Thank You to dsgerbc For This Useful Post:
Scooby South (05-27-2012)
Old 05-25-2012, 10:40 PM   #2
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Not that much. You're good.
pics?
Old 05-25-2012, 11:03 PM   #3
dsgerbc
Yeah, I hope it isn't that much in this light car, with sidewalls being fairly stiff as well. In a few of my first slow subies, that I autocrossed on AS crap-tires, there was quite a bit of deflection.
Just wondering if there's a ballpark 'safe' distance to the suspension pieces for decent street tires.
pics?
If you're asking for pics of 04 bbs on the car - I just tested one
I'm still unsure of a jacking point for the whole front of the car...
Old 05-25-2012, 11:11 PM   #4
Draco-REX
Corner Junkie
Draco-REX's Avatar
I'm not sure about a ballpark. But when you're cornering hard, the worst deformation is on the outside tire. On that tire, the contact patch is being pushed in towards the car which means the top of the tire will want to push out away from the car, so clearance will increase. The inside tire is the opposite but doesn't have anywhere near as much load on it.
One at a time. One at a time.
Old 05-25-2012, 11:46 PM   #5
dsgerbc
I never thought about it properly, but my gut feeling tells me otherwise. I'd expect the whole thread to shift inward in this case. I might be wrong though.
UPD:
I'm not that dedicated.
Old 05-26-2012, 12:59 PM   #6
driver01
Drives: brz 13
On yokohama ad08
Rear tires
driver01 is offline   Reply With Quote
Old 05-26-2012, 03:33 PM   #7
Turbowned
Turbowned's Avatar
Old 05-27-2012, 11:09 AM   #8
Draco-REX
Corner Junkie
Draco-REX's Avatar
UPD:
Originally Posted by driver01 View Post
On yokohama ad08
Rear tires
Interesting, though I'd like to get better views of the top of the tire. I've seen suspension clearance that small or less without issue. I was always of the impression that the outer tire carcass acted like a gyro and deformed to the opposite direction at the top, but it might just be resetting to center.
I think the tire in the second vid is a Bridgestone Potenza RE11.
Old 05-27-2012, 04:40 PM   #9
driver01
Drives: brz 13
My mistake it is re11
Old 05-27-2012, 05:11 PM   #10
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
FINALLY someone took a pic...thank you thank you thank you ... now I can calculate my own stuff....I have the same tire/size 235/40/17 on factory option BBS wheels which are 17x7...sooo I should be good.. I had been asking for that view of the strut/tire for a while now..Appreciate that...now as long as the Stocker BRZ Wheels clear Subaru 4 pots..I will be good
Bill
Scooby South is offline   Reply With Quote
Old 05-27-2012, 05:18 PM   #11
old greg
Rocket Surgeon
Drives: PSM GGA OMG
UPD:
Just to put your mind at ease, that's a bias ply tire. Radials have much stiffer sidewalls and don't see nearly as much lateral deformation at the top of the tire. Here's a more relevant video, a radial passenger car tire being massively abused at Calspan.
Warning: turn down your speakers.
[ame="http://www.youtube.com/watch?v=nmo_dkNZIHM"]Tire Force Test - YouTube[/ame]
old greg is offline   Reply With Quote
The Following User Says Thank You to old greg For This Useful Post:
dsgerbc (05-27-2012)
Old 05-27-2012, 08:00 PM   #12
dsgerbc
^Thanks for the earful, lol.
So, in general, how much would you suggest as a 'safe' clearance? I knew a few guys at autox who seemed to be okay if a credit card can be placed between the tire and the strut. In their worst case, however, the tire would be rubbing the paint off the strut body, not trying to get itself ripped by the edge of the spring seat.
Old 05-28-2012, 05:05 PM   #13
old greg
Rocket Surgeon
Drives: PSM GGA OMG
Hey, I did warn you.
I'd feel comfortable with 3/8" personally. Less than that and I'd put some masking tape on the spring seat, do some aggressive driving then check for signs of rubbing.
Staticfrost (05-30-2012)
Old 05-28-2012, 05:51 PM   #14
dsgerbc
Thanks. That's a number I ran into more than a few times when I tried searching a bunch of different forums; although it seemed to come more often from people driving on R-comp tires.
10.5" wide tire possible?!? Xiao Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 10-11-2015 12:00 PM
Total noob tire-change question Sport-Tech Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 38 04-17-2012 08:15 PM
Plus 0 tire sizing Brzer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-30-2012 09:15 PM
Would you want a spare tire in your FR-S? iff2mastamatt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 120 01-12-2012 11:46 PM
NEW Bridgestone R10 Race DOT tire RRnold Other Vehicles & General Automotive Discussions 2 06-17-2011 06:58 PM
