Old 12-21-2013, 07:16 AM   #1
Kinaa
Kinaa's Avatar
Drives: BRZ (HKS Superchager)
ECUTEK Launch Control for AT transmission
Could anyway explain how to select the Launch Control map for an AT transmissions BRZ/86.
Basically the car has only the Launch control map as you don't need FFS on the AT version.
The tuner that done the job said in order to adjust the Rev car needs to be on P or N then flat foot the brake and gas pedal at the same time , and then use the cruise control to adjust the Rev , which works fine.
But when you try to do it again for second and third time it doesn't work the the RMP just keep going to 7200 then bounce back, so basically it works only once after you switch on the engine.
Any idea on how to the check if the map is selected already and how to do a proper launch with this feature.
Any help will be appreciated
Kinaa is offline   Reply With Quote
Old 12-21-2013, 07:33 AM   #2
s2d4
s2d4's Avatar
you can't. It is dictated by your torque convertor.
Old 12-21-2013, 07:41 AM   #3
Kinaa
Kinaa's Avatar
so what is the point of having a such feature if you can't use it every time you want to use launch control ?
Old 12-21-2013, 07:43 AM   #4
s2d4
s2d4's Avatar
Well, MT uses it. Just not applicable to AT.
Feel free to ask ecutek about it.
Actually think of it like this:
Jumping off a 5m bridge into
1. River - cool.
2. Tarmac - not cool.
Old 12-21-2013, 07:50 AM   #5
Kinaa
Kinaa's Avatar
1. River - cool.
in my opinion it should be the opposite , why do i need a launch control when i have MT transmission.
its not possible to to do a jump start on AT transmissions , so that's why you need a launch control feature .
Old 12-21-2013, 07:52 AM   #6
s2d4
s2d4's Avatar
Read up on torque convertors.
It is a physical limitation.
Old 12-21-2013, 10:58 AM   #7
reardrv
Drives: 2013 Subaru BRZ
Launch control will not work with an A/T, and dropping from Neutral into gear with any A/T is a really bad idea. The only real option would be if you can find a company that makes a higher stall torque converter, which is doubtful for this application.
reardrv is offline   Reply With Quote
Old 12-21-2013, 11:14 AM   #8
Visconti
Drives: 05 STi
Doesn't work on the AT cars
Visconti is offline   Reply With Quote
Old 12-21-2013, 11:38 AM   #9
Lonewolf
Lonewolf's Avatar
Drives: Moped
South Side Performance actually showed their higher-stall torque converter a few weeks back...should be out soon
Found it:
http://www.ft86club.com/forums/showt...nverter&page=2
Old 12-21-2013, 02:30 PM   #10
Kinaa
Kinaa's Avatar
Found it:
Thanks of the info ill be looking on this option
Old 12-22-2013, 01:45 AM   #11
FA20Club.com
Drives: 2013 White Out FR-S
We have an upgraded Convertor as well. We didnt cut the stator to minimize power loss to the wheels. We also have a ton of other upgrades coming along for the AT guys in January.
FA20Club.com is offline   Reply With Quote
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
ECUTek Launch Control in Automatic 01s0uljah Software Tuning 2 08-12-2013 08:45 PM
ECUTek Autoblip & Launch-control features review? mit_peid Software Tuning 10 07-28-2013 05:05 PM
Ecutek Launch Control test video NoFear99 BRZ Photos, Videos, Wallpapers, Gallery Forum 1 06-25-2013 08:53 PM
Launch in AT transmission? K-R Scion FR-S / Toyota 86 GT86 General Forum 20 02-26-2013 09:14 PM
