| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Toyota FT86 2014
Hi Guys,
I bought Apexi Air Filter and while installing it, the air filter box is not closing completely from the bottom, Can anyone advise if he faced the same problem and what is the solution? My installation was the Apexi white print toward the bumper side! |
Drives: 2014 FR-S 6MT Whiteout
Flip the filter around.
Turbo E85
Drives: 13 wrb brz
i removed my intake box and installed filter and re-installed.. took me 3 minutes.
you should try that |
Drives: 2014 Scion FR-S ハチ
It fits fine but you really have to be nice to it or it will pinch it and creat a leak. Take your time by taking the inlet tube out and adjust carefully. It should not be hard to close when it's in right.
Drives: JRSC'd Asphalt FR-S
remove stock box then put it together otherwise it keeps rubbing
Drives: 2014 Pearl BRZ Limited
My perrin was tight as well, echoing other here, but removing the box makes it a lot easier. It's a quick task.
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully | | Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns | |
| Apexi ECV? | ATESIX | Engine, Exhaust, Transmission | 5 | 02-23-2021 02:34 AM |
| SOLD!! Apexi drop in filter, new in box | Jman1759 | Engine, Exhaust, Bolt-Ons | 7 | 03-25-2014 11:26 AM |
| OEM Subaru engine air filter + cabin air filter | autobrz | Mechanical Maintenance and Tools | 6 | 03-09-2014 09:28 PM |
| Perrin Intake Tube + Apexi High-Flow Filter | BMHumanic | Engine, Exhaust, Bolt-Ons | 6 | 08-19-2013 01:57 PM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
