Old 07-05-2014, 01:39 AM   #1
Skorov
Skorov's Avatar
Drives: 86 GTS White
EcuTek Custom Map Not Working
Hi all,
Just been playing around with custom maps trying to setup an overboost fuel cut.
Doing some experiments, I noticed that no matter what I did, my Custom Map M result was always 0. As if the custom map was not on.
Here are my map settings:
Here are the results:
I have tried several different methods of getting this to work, but it seems as though Map M is always inactive.
What am I doing wrong?
Cheers
Skorov is offline   Reply With Quote
Old 07-10-2014, 03:33 PM   #2
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Hi,
Not sure what you are attempting but looking at your logs it looks as though you are just setting a specific value based on RPM only. This will not affect anything in the vehicle (according to your output), as it will only show a value on your custom map M. I would log custom map M to see if the values you are expecting to see line up with your table.
Cheers,
William Knose
Old 07-11-2014, 08:08 PM   #3
Skorov
Skorov's Avatar
Originally Posted by DeliciousTuning View Post
Hi,
Cheers,
William Knose
Hi William,
That's right. For testing purposes I am only expecting to get a reading from Custom Map M Result.
However, as you can see from the logs, Map M result is constant at 0, where for example, I expect to see a value of 2 at 2200rpm.
Any idea why I'm not seeing this?
Thanks a lot for the help. :-)
Old 07-11-2014, 08:18 PM   #4
DeliciousTuning
Understand. Since you are using it for calculations only you should actually be looking at Custom Map M Interim. Since a calculation is usually not a result but used in another formula to get a result. Make sense?
Cheers,
William Knose
Old 07-11-2014, 08:20 PM   #5
Skorov
Skorov's Avatar
Cheers,
William Knose
I see.
However, I'm pretty sure the Interim is also always 0. Before I make an idiot out of myself, let me just go double check quickly.
Old 07-11-2014, 08:27 PM   #6
Skorov
Skorov's Avatar
Confirmed. Always 0.
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 10:35 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 11:42 AM
Tom's working on IS-F looking exhaust Hanzo Engine, Exhaust, Transmission 43 09-08-2013 06:25 PM
Ecutek RaceRom Custom Features Manual iBRZ Software Tuning 33 07-25-2013 01:39 PM
Traffic Nav Not working on my BRZ Indestruct Electronics | Audio | NAV | Infotainment 9 06-19-2012 09:38 PM
